need to get mcleod flywheel balanced for new motor?
Old Apr 18, 2006 | 11:06 AM
Hawk's Avatar
Quick question. I'm going to drop in a crate engine in my car, and I have a mcleod street twin setup(steel flywheel and clutch assembly). DO I need to get this balanced, how do I go about doing this?? THe engine manufacturer? Not sure on this since the engine isn't stock.
Brian
Old Apr 18, 2006 | 11:12 AM
atljar's Avatar
Re: need to get mcleod flywheel balanced for new motor?
Did you have the clutch with your stock engine? If so it is externally balanced and should have a weight on it.
You need to find out what kind of balance the crate motor is. More than likely, it is nuetral balance. This means you need to remove the balance weight from the flywheel, and then have a machine shop double check it.
Old Apr 18, 2006 | 11:24 AM
Hawk's Avatar
I just talked to the engine manufacturer, you're right it is neutral balanced. I'll have to get the flywheel balanced correctly.
HectorM52
Jul 30, 2017 11:46 AM
Ringmaster72
Mar 19, 2015 03:32 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Newgmman
Feb 25, 2015 02:53 PM
