Need to find a wire that is comes on only with engine running
Old May 12, 2005 | 01:36 PM
Beyonce Knowles's Avatar
Like it says, I Need to find a wire that is comes on only with engine running. Does anybody know of one in the engine compartment fuse box? I'm hooking up my CSR pump, and all they don't way which wire to use to activate the relay.
Old May 12, 2005 | 02:33 PM
Alvin@pcmforless.com's Avatar
Re: Need to find a wire that is comes on only with engine running
i used the fuel pump relay pin out.
I had the pinout over at speeddensity.org for the 93 guys but someone destroyed that site
Old May 12, 2005 | 09:44 PM
You can use a meter or test light to be sure.
Old May 12, 2005 | 11:47 PM
97WS6SCharged's Avatar
You can use the ignition fuse in the underhood fuse box. Works fine.
Jazsun
Dec 29, 2014 12:14 PM
cmdeshon
Dec 12, 2014 10:51 PM
Jul 4, 2005 05:00 PM
Lions3
Apr 11, 2003 10:55 AM
