need a few tips for storing
Old Oct 26, 2006 | 10:51 PM
Misfits's Avatar
i'm storing my 97 Z over the winter.. i got the basic tips...
1. add stabilzer
2. oil/filter change
3. check coolant freezing point
but theres one thing i'm not to sure.. should i fill up my gas tank or keep it half full or little as possible? the car is going to be stored in temptures as cold as -35celsuis (-45 w/ windchill).. It's in a car port,closed from 3 sides and open from the front. any tips would be great
Old Oct 26, 2006 | 11:04 PM
oneslowz28's Avatar
fill it up and add enough fuel stablizer to hold the full tank.
crank it up once a week and let it get to full operating temp and let it idle for 5 or so min to boil off any condensation that may have accumilated<sp>. I would also give it a good waxing
Old Oct 27, 2006 | 10:35 AM
19camaro71's Avatar
what he said.. some will recommend running the gas real low, well be prepared for the car to run for crap in the spring. fill it up, i don't even use stabilyzer, its only 3 months or so. the car runs fine, but i do run the gas low in the spring before refilling, just to run most of the old stuff out. wax it, get a decent car cover (sheets work nicely, all of my family's car use them) but a custom car cover is nice too. Whenever you do start it, if its not once a week or is, let it get up to normal operating temp, a good 15 minutes should do it.
13qtr
Oct 28, 2016 08:11 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
autoxr166
Sep 25, 2015 04:21 PM
Sep 18, 2015 03:46 PM
jackpawt883
Sep 10, 2015 08:53 PM
