Is my Knock sensor trashed?
Old Oct 27, 2006 | 07:23 AM
wrd1972's Avatar
Doing head and cam install so I pulled the knock sensor to drain the block completely. I used a 7/8" socket and the internal part of the sensor turned justa a tad while the outer threaded part remained torqued to the block.
I then got the channel locks out and the sensor broke loose easily and came out.
My question, is my sensor now trashed since the internal part rotated just a tad, or do I need a new one?
Old Oct 27, 2006 | 07:57 AM
Sweetred95ta's Avatar
Mine did that when I tried replacing it. Test it with an ohm meter and see if it is still grounding to the block (put red tip in the sensor and touch the black tip to the block). If it is, I would imagine you're ok. The values are on Shoebox's website. It should also throw a DTC43 if it's not working.
Old Oct 27, 2006 | 11:16 AM
LT1 POWR's Avatar
They are not too expensive if it was damaged. It might be a good idea to replace it anyways, while you already have the block drained, since they sometimes go bad over time.
KYWes
Jun 14, 2022 06:52 AM
350350
14
Aug 11, 2015 12:03 PM
HectorM52
Parts Wanted
Aug 8, 2015 08:12 PM
Noct
Jul 14, 2015 01:18 AM
asilomar244
Jul 12, 2015 05:53 AM
