Need to drop oil pan, should I add HV oil pump now?
Old Jun 17, 2003 | 04:57 PM
FastZinTennessee's Avatar
I remember there have been a few people on here that say not to use a high volume pump because it can run the sump dry on hard cornering.
However, I'm not in to road racing, so this isn't an issue with me. Plus I've had a problem with losing some oil pressure in second gear pulls. It will drop about 20psi midway through the pull and then come back up again.
I just need some opinions because oil pumps are cheap, and now would be the time to do it.
Any suggestions/thoughts/comments appreciated!!
John
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Queens94z28
Dec 20, 2014 09:11 PM
Elcojoe
Nov 17, 2014 10:27 PM
