Need a connector (helphelp)
Old Dec 30, 2003 | 11:08 AM
KWKSLVR's Avatar
S.E. Region Moderator
Exclamation Need a connector (helphelp)
I managed to snap the wire that goes to the thing-a-majig behind the FPR. The metal piece that goes into the connector is chewed up, in fact it's gone. I need to know where to get another one. Advance and Autozone just give me confused looks.
I'd prefer to not replace the entire switch because I'm sure its linked to about a million other wires that will cost me a small fortune.
Old Dec 30, 2003 | 02:59 PM
Do you mean the oil pressure sensor, screwed into the block behind the rear edge of the intake manifold?
oil pressure sensor
Old Dec 31, 2003 | 02:57 AM
KWKSLVR's Avatar
Sho nuff.
Pic #1 What I'm talking about slides into the bottom center hole
Pic #2 is the bottom center. And yes, that is an autographed picture of Mr. Rogers next to my Diploma in the background.
Old Dec 31, 2003 | 08:27 AM
The connector for the oil pressure switch is GM PART # 12085499 and is ACDelco #PT121. It may come with more wires than the one you need. Just ignore or remove the others.
Old Dec 31, 2003 | 12:32 PM
KWKSLVR's Avatar
Awesome! Thanks man. I don't know where you keep coming up with part numbers because I couldn't find that one anywhere. Hopefully that'll get it. That wire is costing me $20
Jeff1904
Jun 5, 2016 05:00 PM
football4life
Oct 4, 2015 07:48 AM
Double aught
Oct 2, 2015 11:29 PM
autoxr166
Sep 25, 2015 04:21 PM
frankrizz
Sep 23, 2015 04:21 PM
