Need coil help fast...please
Old Oct 18, 2003 | 02:49 PM
ead94z28's Avatar
Exclamation Need coil help fast...please
I am replacing my coil. I removed the old one and it looks like it is riveted to the back bracket. How do I get it off so I can put the new on that bracket? Please, any info would be great.
Old Oct 18, 2003 | 02:52 PM
Go to my Tech Page and look in the "How To's".
Old Oct 18, 2003 | 02:55 PM
ead94z28's Avatar
Thank you, thats just what I needed.
Old Oct 18, 2003 | 03:35 PM
ead94z28's Avatar
Shoebox
I'm also replacing the knock sensor. Do you have to drain all coolant to do that? I read somewhere that you did.
Old Oct 18, 2003 | 06:16 PM
Originally posted by ead94z28
Shoebox
That hole in the block is practically the lowest spot in the cooling system, so coolant is definitely going to come out. You could try to put the new sensor in as fast as you can, but it will be messy (you might need goggles).
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
68camaroboltz
Oct 5, 2015 01:46 PM
Z Power
Sep 19, 2015 11:19 PM
