need air intake manifold
Old May 1, 2006 | 10:24 PM
formula12345's Avatar
i wanted to rebuild my engine and was thinking of getting the LT-4 intake manifold. i heard GM is discountineing the item?? i wasnt planning on rebuilding for at least a year. will someone else have one out by then? will it be brought back any ideas on what i should do thanks
Old May 1, 2006 | 10:57 PM
Re: need air intake manifold
Are you also getting LT4 heads? The LT4 intake won't even bolt on LT1 heads without minor machine work to either the heads or manifold. Then when you get it bolted on it won't be any different than the LT1 intake manifold. The LT4 intake is virtually identical, except for some extra metal at the top of each runner to allow it to be ported to match the LT4 heads (which it doesn't match from the factory).
Edelbrock has announce LT1 and LT4 intakes, but even though they are in the catalog, there is no indication when (or even if) they will actually be avaiable. We're all still waiting for Edelbrocks first version of the LT1 intake, which appeared in their catalog in 1995..... and was never actually sold.
Do a "search"..... the Edelbrock intakes have been the subject of several threads over the past couple months.
Old May 2, 2006 | 10:56 AM
i was goign to get the LT-1 to LT-4 conversion kit, so yea i was goign to get the heads too, i just dont want to be high and dry when it comes time to rebuild
Old May 2, 2006 | 12:01 PM
teke184's Avatar
there are much better choices when it comes to heads.
just get some ported stock lt1 castings from Lloyd Elliot and a mild cam....
Old May 2, 2006 | 01:45 PM
You can't get the LT1->LT4 conversion kit, because GM doesn't make it any more..... they don't make the intake manifold, so they can't make the "kit". Maybe some catalog places have a kit left, but its not likely.
Listen to advice regarding:
http://www.eportworks.com/
Old May 2, 2006 | 04:28 PM
if i could get a kit would you guys recommend it ? i hear good thing about these LT-4 engines let me know
Old May 2, 2006 | 05:03 PM
fasteddie94's Avatar
NO! It's overpriced for the gains you actually get listen to Injuneer and teke, talk with someone like Lloyd or if you're dead set on LT4 heads get a set of AFRs.
More power can be made for the same money following the same head and cam approach. Do yourself a favor and look at all the other options out there. The cam is also pretty small in the LT4 "kit."
Old May 2, 2006 | 05:32 PM
96redrum's Avatar
I also was going to put the lt4 setup in my SS but as of right now all i have is the ported by L.E. LT4 heads. I emailed Edelbrock about a month ago and they emailed me back saying that they were going to be releasing the 94-97 LT1 & LT4 intakes in Jun. no later then July. they even gave me the part #'s#7101(LT1)-#7109(LT4). hopefully they really r going to be coming out cause I got these heads but no intake, and I aint buying an LT4 intake for $1000 bucks on ebay or anywere else for that matter.
Old May 2, 2006 | 06:30 PM
you can have someone modify a stock one to work. it's roughly 200 bucks.
Old May 2, 2006 | 10:18 PM
veee8's Avatar
Anyone have any pics of welded up LT1 intakes?
rjc1629
Jan 27, 2015 10:46 AM
CARiD
Jan 27, 2015 06:27 AM
thenewkid
Nov 27, 2014 09:41 AM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
