need Advise replacing head gaskets LT1
Old Sep 3, 2005 | 04:55 PM
wolfepack95's Avatar
Question need Advise replacing head gaskets LT1
Hey Guys i need some help im replacing my head gaskets on a 95 Z28 LT1. what do i have to do to get the power steering pump out of the way. Can i leave it connected also do i have to remove or unbolt the AIR Compresor.
Thanks in advace Im hoping for a quick responce.
Old Sep 3, 2005 | 05:06 PM
FastZinTennessee's Avatar
Re: need Advise replacing head gaskets LT1
If you spin the power steering pump pulley, you'll be able to get access to the (2) bolts holding the pump to the bracket. You can leave the pump connected, remove those two bolts and move it out of the way a little. Not sure about the AIR compressor though, it was one of the first things I took off when I bought the car
Old Sep 3, 2005 | 05:11 PM
Thanks FastZinTennessee i got those two bolts out. im not sure how to get the bracket that it was bolted to out of the way I can only see one bolt holding it on to the Head.
Thanks for the reply
Old Sep 3, 2005 | 09:35 PM
No problem. If I remember correctly, I left the bracket in place when I removed and reinstalled the heads.
Old Sep 4, 2005 | 12:20 AM
OBE1 95Z28's Avatar
The accessory bracket can stay put, you just need to remove the bolt that holds the bracket to the head.
Old Sep 4, 2005 | 09:45 AM
Thanks guys
Thats what i was hoping. Also is it safe to leave the fuel lines attached to the fuel rail and just lay it out of the way?
Old Sep 4, 2005 | 10:20 AM
joeSS97's Avatar
Yes,it is.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
