need Advise replacing head gaskets LT1
Hey Guys i need some help im replacing my head gaskets on a 95 Z28 LT1. what do i have to do to get the power steering pump out of the way. Can i leave it connected also do i have to remove or unbolt the AIR Compresor.
Thanks in advace Im hoping for a quick responce.
Re: need Advise replacing head gaskets LT1
If you spin the power steering pump pulley, you'll be able to get access to the (2) bolts holding the pump to the bracket. You can leave the pump connected, remove those two bolts and move it out of the way a little. Not sure about the AIR compressor though, it was one of the first things I took off when I bought the car
Thanks FastZinTennessee i got those two bolts out. im not sure how to get the bracket that it was bolted to out of the way I can only see one bolt holding it on to the Head.
Thanks for the reply
