need advice
Old Feb 21, 2007 | 11:10 AM
diamondhill's Avatar
Question need advice
i just bought another lt1 car a 95 camaro z28 everything seems to be fine ,all stock except the exhaust is dumped right under the passengers seat it has factory manifolds, y-pipe, then about a 2 feet of 2 1/2 in. pipe dumped, it sounds kinda cool i like the noise , except when im on the highway going about 70 then let off the gas it vibrates and pops a little , my buddy told me it wasnt good for the valves , is this true , is it ok to drive like this until i get a full exhaust , or should i leave it alone?
Old Feb 21, 2007 | 11:16 AM
2000GTP's Avatar
Your not going to burn up or damage your valves, you'll be fine. All of the popping and extra noise is just a result of not having your exhaust hooked up to a muffler anymore.
Old Feb 21, 2007 | 11:34 AM
do i gain or lose performance or power by keeping it the way it is?
Old Feb 21, 2007 | 11:48 AM
2000GTP's Avatar
You are bypassing the muffler and essentially running an exhaust cutout which many of us use. Cutout are well documented for providing gains so long story short, you should be seeing a power increase from what you did.
Old Feb 21, 2007 | 12:00 PM
ok well thank you for your help
Jeff1904
Jun 5, 2016 05:00 PM
David Dempsey
Mar 12, 2016 12:42 AM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
68camaroboltz
Oct 5, 2015 01:46 PM
