Need advice
Old Dec 18, 2003 | 02:01 PM
Sweetred95ta's Avatar
Need advice
I did something to my car a few weekends ago. It involved spraying nitrous on platinum plugs. It was missing and I couldn't figure out why. Well, a week after I did this, it started knocking real loud and squeaking from the passanger side. I thought the motor was shot so I pulled the heads to see what kind of damage I did. I burnt 5 valves and melted one of them. The heads otherwise look real good still. Now, the problem, I drained the oil, to look for metal flakes and I found nothing. I was thinking I spun a bearing and that was causing the knocking and squeaking. But wouldn't I have found metal flakes in the oil? I turned the motor over (bare block) and it sound good, no squeaks or noise at all. Should I drop the pan, or the whole motor. Which one is easier??? I need advice bad.
Thanks,
Benji
Old Dec 18, 2003 | 02:12 PM
Fastbird93's Avatar
When I spun a bearing in my beater this summer, I dismantled the old motor after taking it out because I, just like you, wasn't finding metal in the oil. I found all of the metal chunks held to the side of the block at various points. I would say to see if there's a metallic sheen to your oil.
Old Dec 18, 2003 | 02:36 PM
The oil looked good. No "metal sheen" at all. Just a little burnt. Filtered through it and couldnt find anything.
Benji
Old Dec 18, 2003 | 04:34 PM
Fastbird93's Avatar
Well, since you've already got the heads off, how difficult would it be to just take the rest of the motor out and pull the pan for a look?? That's probably going to be your best bet.
On another note, you mentioned that you had farked up some valves. That could possibly entail a lot of your knocking sound in itself.
Old Dec 18, 2003 | 04:36 PM
WS Sick's Avatar
I would drop the pan and take a look around. You can loosen the K member and let it drop down a bit to get the pan out.
Old Dec 19, 2003 | 02:05 AM
That's another thing is that I'm trying to figure out if a melted or a burnt valve could cause any knocking or squeaking.
Benji
Jeff1904
Jun 5, 2016 05:00 PM
David Dempsey
Mar 12, 2016 12:42 AM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
68camaroboltz
Oct 5, 2015 01:46 PM
