Nedd step/step install info on trans cooler
Old Jun 22, 2003 | 11:40 PM
FLU
Guest
Posts: n/a
Unhappy Nedd step/step install info on trans cooler
i need install info on the b&m trans cooler- how to install it on my 94 z28. i want to install it in front of the radiator. but i need a step by step on these project. thanks
Old Jun 23, 2003 | 04:52 AM
anaik's Avatar
You'll find it on this site.
http://www.bfranker.badz28.com/fbody/guides.htm
Old Jun 23, 2003 | 09:32 AM
FLU
Guest
Posts: n/a
thanks
Old Jun 23, 2003 | 05:37 PM
revtime's Avatar
Brents is a good one to use, I have seen one on here that they drilled holes through the air dam for the hoses
I myself cut the crimped rubber off mine with a tubing cutter and did not have to use the brass couplings at all. Also I have no AC anymore and the radiator has a plastic holder for one of the AC lines on the condenser this holds the rubber line coming from my tranny cooler perfectly.
Old Jun 23, 2003 | 06:07 PM
FLU
Guest
Posts: n/a
i installed it today- easy mod once you get working on it.
94Z28LS1toLT1
Parts Wanted
Jan 21, 2015 04:37 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
bernie1951
Dec 10, 2014 10:03 AM
thenewkid
Nov 27, 2014 09:41 AM
lbrowne
Aug 22, 2002 06:21 PM
