nasty stumble
Old Apr 17, 2004 | 08:19 PM
camaro9402's Avatar
nasty stumble
i have a 94 z28 and recently it has developed a bad stumble like its not getting gas it wont do it all the time and its just when i start it up and go. it dont last that long mabye a 1 min. and the most and then ist fine. i changed the fuel pump today and it still seems to be there i dont know what is next fuel pump maybe? i dont know if someone could help me out that would be great thanks
Old Apr 17, 2004 | 08:48 PM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
Re: nasty stumble
Any codes??? Um you said you changed your fuel pump.....?? Fuel filter maybe...
Old Apr 17, 2004 | 09:17 PM
camaro9402's Avatar
no my bad i ment to say i changed the fuel filter and no i dont have any codes
Old Apr 17, 2004 | 09:57 PM
Robs97Z28's Avatar
you should check fuel pressure this will tell if it is a fuel problem or not. the reading should be 41 to 47 with the vaccum line off. It should drop 3 to 10 psi with line on.
revrider
Cars Wanted
Apr 5, 2016 10:06 AM
93 RedBird
Nov 15, 2015 08:24 AM
tommalcolm
Sep 11, 2015 03:39 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
C4m4roJoe
Jul 19, 2015 10:59 PM
