Name that sensor
Old May 5, 2004 | 10:30 AM
TrouserSnake's Avatar
Name that sensor
Its tucked behind the water pump in a little crevise not seen by the naked eye... You would have to be looking for it...
I cant find the right plug that goes in there...
Is it cruicial that this is pluged In?
Old May 5, 2004 | 11:06 AM
dreamer1q's Avatar
Behind the waterpump almost hidden from view, but it plugs in from the top???????? Thats the opti.......
Old May 5, 2004 | 11:21 AM
The Opti Is pluged.. In im pretty sure I did that as soon as put it on... But maybe.. just maybe I forgot.. Thanks Ill give it a second look
Old May 5, 2004 | 11:25 AM
dreamer1q's Avatar
The Opti is a double plug setup....you plug the harness into the opti, and then plug the engine harness into the opti harness. You might have done one and not the other
Old May 6, 2004 | 02:48 PM
Dave Feerst's Avatar
yes, the opti harness is a 4 wire harness about 15 inches long, it goes into the opti in the spot where you described and it couples to the main wiring harness near the #6 intake runner.
generaldave
Sep 25, 2015 06:48 PM
98-LS1Z28
Sep 8, 2015 03:12 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
