Name that clunk... Rear or trans
Old May 18, 2003 | 12:42 PM
Zrag's Avatar
When driving at hwy speeds or stop light driving ONLY when hot the car develops a clunk coming from the rear area. It is only heard when off idle and again hot. when driving there are no sounds and shifts firm and on the money. I don't think it is the trans as it is relatively new in OCT with about 6-7k of NORMAL driving plus it is a stage II rebuild. I did just change my rear gear oil three weeks ago with semi synthetic and I did fill it. I know my way around cars and do ALL my own work. This noise has me baffled.
It also does it a bit when hot when going into rev. There are no leaks on the dif so there is oil there.
I'm about to raise the a$$ and look what it could be so suggestions are welcomed.
It could also be a binding brake, not sure though.
Old May 18, 2003 | 01:39 PM
96LT14u2Nv's Avatar
if any clunking happens around corners, i would check out your panhard bar. hope it helps.
Old May 18, 2003 | 02:21 PM
Zrag's Avatar
Nope not around corners. Going straight only.
Old May 19, 2003 | 12:22 AM
fbird95's Avatar
Still could be the panhard bar. I have just about the same issue. I checked the panhard bar and bushings, they look fine. I think i'll change them anyway just incase, maybe use some poly bushings instead of those soft factory ones.
Old May 19, 2003 | 12:25 AM
Kain's Avatar
Jack up the rear end of the car and take a look. It could be a shock thats gone bad, LCA, panhard bar, rear sway bar.
It might be the tranny mount, but I doubt it. Worth taking a look at for grins.
Old May 19, 2003 | 09:31 AM
Zrag's Avatar
Thanks for the replys.
I didn't get a chance to get under there yesterday. However I don't think it is the bushings on panhard bar or shocks. Reason is it seems as though the clunk sound also holds the car back even if it is just for a sec. it is not a lot but you feel it and it is only off idle.
What can be described as the sound is lets say you power brake a bit and before the wheels spin the brakes make a noise as the try to hold the car back. That is similar but add more of a metal sound and that's it.
Old May 19, 2003 | 09:39 AM
LWillmann's Avatar
What about your universal joints?
I have heard of them clunking when needing to be replaced.
Old May 19, 2003 | 09:57 AM
djc485's Avatar
When you replaced your diff. fluid did you use the additive for the ltd. slip?
Old May 19, 2003 | 10:09 AM
Zrag's Avatar
djc485 I actually didn't use any additive. I thought semi synthetic was good. When I bought the oil I looked around and asked for the additive but they looked at me like they had no idea what I was talking about.
Besides this is my 5 f-bod from 94-98 Zs and I changed the dif oil to my 96 and 97 and never had any problems not using the additive.
What is in it?
Old May 19, 2003 | 11:00 AM
GoFast908Z's Avatar
Member
I had a similar problem once. I had a broken tranny mount, and a bent rear axle. You might want to check the torque arm too.
GoFast908Z's Avatar
Member
Old May 19, 2003 | 04:08 PM
faded93bird's Avatar
with all above said U-joints could be another culprit
it sucks to chew one of those beleive me
Old May 19, 2003 | 05:28 PM
Zrag's Avatar
It could be a U joint but the car I got my Alum DS from had like 30k plus I have no vibs at any speed and no rear whine either. I've still got my 342 complete rear to put in. I just like saving on gas.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jan 13, 2015 09:52 PM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
siguy
Nov 27, 2014 10:07 AM
