Name that clunk... Rear or trans
When driving at hwy speeds or stop light driving ONLY when hot the car develops a clunk coming from the rear area. It is only heard when off idle and again hot. when driving there are no sounds and shifts firm and on the money. I don't think it is the trans as it is relatively new in OCT with about 6-7k of NORMAL driving plus it is a stage II rebuild. I did just change my rear gear oil three weeks ago with semi synthetic and I did fill it. I know my way around cars and do ALL my own work. This noise has me baffled.
It also does it a bit when hot when going into rev. There are no leaks on the dif so there is oil there.
I'm about to raise the a$$ and look what it could be so suggestions are welcomed.
It could also be a binding brake, not sure though.
Still could be the panhard bar. I have just about the same issue. I checked the panhard bar and bushings, they look fine. I think i'll change them anyway just incase, maybe use some poly bushings instead of those soft factory ones.
Jack up the rear end of the car and take a look. It could be a shock thats gone bad, LCA, panhard bar, rear sway bar.
It might be the tranny mount, but I doubt it. Worth taking a look at for grins.
Thanks for the replys.
I didn't get a chance to get under there yesterday. However I don't think it is the bushings on panhard bar or shocks. Reason is it seems as though the clunk sound also holds the car back even if it is just for a sec. it is not a lot but you feel it and it is only off idle.
What can be described as the sound is lets say you power brake a bit and before the wheels spin the brakes make a noise as the try to hold the car back. That is similar but add more of a metal sound and that's it.
djc485 I actually didn't use any additive. I thought semi synthetic was good. When I bought the oil I looked around and asked for the additive but they looked at me like they had no idea what I was talking about.
Besides this is my 5 f-bod from 94-98 Zs and I changed the dif oil to my 96 and 97 and never had any problems not using the additive.
What is in it?
What is in it?
It could be a U joint but the car I got my Alum DS from had like 30k plus I have no vibs at any speed and no rear whine either. I've still got my 342 complete rear to put in. I just like saving on gas.
Jan 13, 2015 09:52 PM
