Name All Causes Of Running Rich You Can Think Of
Old Dec 7, 2004 | 06:53 PM
  #16
mzgp5x's Avatar
Re: Name All Causes Of Running Rich You Can Think Of
Bad O2 could be the problem when they come on line in closed loop mode. I have had this problem since I am blown and wasted many. A cold start problem is different because it is open loop mode @ start.
___________________________
"97" 15psi blown intercooled 72# inj.
Old Dec 7, 2004 | 07:43 PM
  #17
Kataklysm's Avatar
O2s have been replaced and read fine on the scanner. Both very sparatic reading, neither are delayed or read lower than the other.
Old Dec 7, 2004 | 09:08 PM
  #18
slimdawson's Avatar
What are your blms?
Even when my blms are where they should be, my car still smells "rich". Smells like race fuel.
Old Dec 8, 2004 | 06:36 PM
  #19
Kataklysm's Avatar
I gotta hook it up to the scanner to get the number for ya. Unfortunately my car isn't with me right now so I can't do that. It varies from 100-800 though I believe.
Old Dec 8, 2004 | 10:30 PM
  #20
slimdawson's Avatar
It only varies from 108-160 stock. 128 being optimal. 108 is rich and the pcm is pulling fuel at the max rate. Mine was like that but I could find no problems so I adjusted the injector constant to get them nearer to 128. Try to be on just under 128 if you have the tuning capability so it doesn't pull fuel at wot. BLM=block learn multiplier. Just a fyi so you are sure of what you are looking at. When you said 100-800, I am assuming you were thinking of the O2s.
Old Dec 8, 2004 | 10:41 PM
  #21
SSmoked's Avatar
Sorry for the off topic but, slimdawson that is one of the nicest old body style camaros i have ever seen. Awesome car man, get some more pic's!
Old Dec 9, 2004 | 03:07 PM
  #22
slimdawson's Avatar
Thanks ssmoked. I just added some last night. I don't know if you saw the new ones or not.
Old Dec 9, 2004 | 04:22 PM
  #23
Fastbird93's Avatar
Verify what your Long and Short term fuel trims are doing to get an idea of how rich.
In my case, my LTerms (BLM's) were pegged at 108. Turns out I had lifters that weren't holding a pump when warmed up. So there's another for the list.
Old Dec 10, 2004 | 11:46 AM
  #24
Kataklysm's Avatar
Yes I thought you meant O2 readings. The fuel trim levels I wanna say are around 120-128. Thats if I'm thinking right. This weekend I'll get the scanner on it and write it all down so I can post an exact reading of what it's doing.
Old Dec 10, 2004 | 11:28 PM
  #25
slimdawson's Avatar
If they are over 108, your car isn't running rich. Unless your O2s are gone. Or your tune is off.
DirtyDaveW
Dec 1, 2016 05:37 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Donwest22
Parts Wanted
Dec 12, 2014 05:58 PM
Rich_z28
May 6, 2003 08:38 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
