N/A 355 104mph in the 1/8th 6-speed VIDEO
Hi all,
I went to the track again and got some new numbers. I only managed to get a few runs in, but the results are decent. The track conditions where not that good, so launching off the two step was not going to work (blowing the tires off at the line). I had to drive it totally by feel. Getting a 6-speed down the track is tricky business. As I said before the weather and the track where crappy, but I did the best I could for the conditions.
Results:
Run 1
1.53 60'
6.98 660'
104.44 MPH 1/8
10.88 @ 127.14 MPH 1/4
Run 2
1.55 60'
6.99 660'
101.1 MPH 1/8
10.90 @ 127.26 MPH 1/4
The DA was a best of 1,700'
Humidity: 71%
Water grains per pound: 65.1
Track temp: 75
Race weight: 3450 lbs
Here is a video of the runs.
I am sure with better track conditions I will be able to launch off the 2 step and shave a little more off of the ET, and add some MPH.
I weighed the car at the track and the scale said 3450. I weighed the car in Rockingham and the scale said 3350. I don't know which scale to trust
. I ran about the same amount of fuel, and I weigh between 160-170, so I don't see how the race weight varied by 100 lbs.
I changed over to a 4:88 gear to help keep the car from bogging down like it did with the 4:10. So far I like it. Even with the conditions being what they where the car was consistently quicker and faster.
Results:
Run 1
1.53 60'
6.98 660'
104.44 MPH 1/8
Run 2
1.55 60'
6.99 660'
101.1 MPH 1/8
Humidity: 71%
Track temp: 75
. I ran about the same amount of fuel, and I weigh between 160-170, so I don't see how the race weight varied by 100 lbs. I changed over to a 4:88 gear to help keep the car from bogging down like it did with the 4:10. So far I like it. Even with the conditions being what they where the car was consistently quicker and faster.
Nice runs but did something go wrong on the first pass b/c you have almost the same mph and ET going 104.4mph or 101mph at the the 1/8th? The pass with 104.4 should be closer to 130+mph unless something is not right. Later
Javier97Z28: I try to shift about 7,700 RPM, but in reality it varies by about 200-300 RPM (mainly in the first few gears). At 8,000 it's on the limiter. My friends say it sounds like a phone ringing LOL.
jasonisdn: It should be a couple of weeks. Send me a PM.
Only 104mph...I expected at least 110 =(
Haha JK. That car is running mean. I can't even imagine trying to run a 6spd that fast. One little change or variation and the run can be way off. Seat time will be your best friend with that setup.
I feel like shipping you my th400 so you can get out there and break the track for a change.
Wow, that thing is killer. I wish my little 350 ran like that.
