Mysterious Rich Condition FIXED!
Old Jul 11, 2005 | 01:57 PM
TMorgan800's Avatar
Sadly, when I had my Cat removed at the ghetto shop in Bell, CA for 50 bucks, they did not seal up the weld where they put the "off road" pipe. This was done 10mo. ago at least.
Last week, I bought a Texas Speed, Rumbler system (not the tru-dual sys.) and had a different shop in Santa Ana, Azteca Mufflers, weld it on. I bought some new Bosch o'2s and had them put in as well.
During the post install check of the system, they felt around for any leaks and noticed a major leak right where the off road pipe was!! I wanted to scream. The car was running like crud for almost a year and it was a stupid exhaust leak!
Needless to say, the car runs like a new beast. The exhaust is louder than sin! It is unreal!
I have a question though. Did I foul all of my spark plugs?? with the rich condition caused by the leaky exhaust?? It used to smell AWFULL.. now.. I can barely smell it when I pull up to a light.... was I smelling overly rich exhaust or just the exhaust leaking from under my feet??
Thought this might help anyone who has experienced similar problems.
--Troy
Old Jul 11, 2005 | 02:01 PM
blind527's Avatar
Re: Mysterious Rich Condition FIXED!
How much HP do people usually lose with very small exhaust leaks?
Old Jul 11, 2005 | 02:19 PM
RocCityZman's Avatar
I would check a couple plugs and see if they are carbon fouled. I would also check the oil and see if you have any fuel in the crankcase. This happened to me because of a rich condition (different reason) and I am trying to flush out the oil to get the gas out. I think the extra fuel did a nice job cleaning my crank case and lower end though as it was BLACK as can be after about 500 miles.
Old Jul 11, 2005 | 03:41 PM
TMorgan800's Avatar
Thanks for the ideas so far.
If I change my plugs.. what plugs should I use??
--Troy
Old Jul 11, 2005 | 03:52 PM
faded93bird's Avatar
As for plugs I run Auto Lite 104's the wory great for me.
Old Jul 11, 2005 | 03:54 PM
TheBiz's Avatar
--Troy
Stick with ACDelco, but get their platinum plug. I have had nothing but a good experience with them.
Old Jul 11, 2005 | 11:46 PM
JWS6's Avatar
Ive heard the AC platinum's "pad" falls off the electrodes. SEaRCH on this one. I'm using autolite 104's
Old Jul 12, 2005 | 02:35 AM
Randy L's Avatar
I have NGK TR-55 Iridiums in mine and they seem to work great! Runs very smoothly.
Old Jul 12, 2005 | 06:37 AM
ZMAN Z28's Avatar
If you are running a power adder then gt the 104's. If not then keep the stock heat range.
Z
Old Jul 12, 2005 | 08:28 AM
matt65's Avatar
--Troy
Was the Leak right in front of your O2 sensor(s)?
Old Jul 12, 2005 | 08:16 PM
'93 Z28's Avatar
Talking Re: Mysterious Rich Condition FIXED!
I prefer the AC-Delco Rapidfires. If you don't go with a platinum plug make sure you gap it at .035" not the standard .050".
Jay
Old Jul 18, 2005 | 02:31 PM
TMorgan800's Avatar
The leak was right after the o2's at the collector/y pipe.
There is an o2 on each header about 10-12inches away from where the leak was.
I can only assume that some funky(non exhaust gas) air was gettin in causing the o2's to read a lean condition and adding fuel...right?
--Troy
grabbem88
Apr 16, 2015 06:57 PM
Magenta_Hearts
Mar 22, 2015 03:36 PM
Iamherefornow
Jan 26, 2015 04:57 PM
siguy
Nov 27, 2014 10:07 AM
MislMan
Jul 19, 2002 11:41 AM
