Mysterious Dead Battery
Old Feb 18, 2004 | 12:13 AM
orrink's Avatar
OK I must be going nuts. I installed a new battery about a week ago. The old one which wasn't that old barely cranked my Z. The new one seemed fine and after a couple of days of non use is dead and I mean dead. With a jump from by other car I get the interior lights and the ticking sound but no turnover. What the hell is going on here? HELP
Old Feb 18, 2004 | 05:29 AM
slopokrodrigez's Avatar
I'll wager money you have a bad connection. check the grounds at the frame and the engine. Dont forget the positive battery cluster at the passenger fender.
Put a voltmeter across the battery and you should see about 12.6V. Now move the lead from the negative terminal to a clean spot on the engine with the other lead still on the +battery terminal. The reading should be the same.
Old Feb 18, 2004 | 02:43 PM
BUBBA's Avatar
Connections or bad/incorrect new battery.
Seen new batteries that were junk because the terminals actually turned inside the case.
Old Feb 18, 2004 | 03:42 PM
GetaZforgetGT's Avatar
I've had a relay stick and drain that battery on my Jeep.
Let me tell ya, that was fun trying to find that one.
Old Feb 18, 2004 | 04:32 PM
1fast95Z's Avatar
I had a slow "leak" in my electrical system. Somewhere in my powerseat/rear defrost there was an open circuit. You might want to troubleshoot the possibility of an open circuit somewhere.
Old Feb 20, 2004 | 12:04 AM
orrink's Avatar
It appears to have been the light in the center console which satys on since the button isnt being depressed
Formula Steve
Sep 19, 2023 08:31 AM
68camaroboltz
Oct 5, 2015 01:46 PM
jackpawt883
Sep 10, 2015 08:53 PM
