my true duals, summit x-pipe kit to pacesetter long tubes
Old Feb 14, 2006 | 08:00 PM
luckyou03's Avatar
I read on here a alot of people want to know how to make this work so here ya go. You just need some 4 1/4" extensions.
Old Feb 14, 2006 | 08:10 PM
jchevy's Avatar
Re: my true duals, summit x-pipe kit to pacesetter long tubes
Looks good. What kind of mufflers are those? What are the dimensions?
Old Feb 14, 2006 | 08:13 PM
Evil Eric's Avatar
Sweet, thats the exact same setup I'll have, just with Thrush magnums
Old Feb 14, 2006 | 08:15 PM
luckyou03's Avatar
single chamber flowmaster race mufflers
Old Feb 14, 2006 | 08:20 PM
DarkHorse's Avatar
How loud would you say that setup is - installed yet?
Old Feb 14, 2006 | 08:24 PM
luckyou03's Avatar
I'm installed a new torque arm tonight, but I'll probably have it ready by the end of this week. I expect it to be loud, I just hope it's not obnoxious.
Old Feb 14, 2006 | 08:40 PM
Jeff H's Avatar
Just as a note, that setup would not be legal in NJ because the tailpipes have to exit from under the vehicle and exit beyond any window that can be opened(obviously not including rear hatch). I would expect that to be pretty loud just from the looks of those mufflers.
Old Feb 14, 2006 | 08:51 PM
93black-ta's Avatar
thanks, that helps out alot. i'll be starting my kit as soon as i get some free time. did you have to clearance the drivers side pipe to keep it from banging on the car?
Old Feb 14, 2006 | 09:25 PM
JoeliusZ28's Avatar
thanks for posting up, theyre added to my library
Old Feb 14, 2006 | 10:28 PM
luckyou03's Avatar
yes, a 5lb mini hammer works best.
Old Feb 14, 2006 | 10:58 PM
bowtieman_racin's Avatar
looks good I ended up getting 2 new pieces made at a local exhaust shop that are longer I should have just used the extensions though. I used dynomax bullets, and on my collectors I used band clamps insted of putting flanges on it makes for a real easy removal when working underneath.
Old Feb 15, 2006 | 12:09 PM
2000GTP's Avatar
It looks very nice, I am jealous.
Old Feb 15, 2006 | 12:19 PM
blkchevyz's Avatar
looks good.
i went from bullets to some flowmaster race muffler and man did it sound way better... less like a truck
Old Feb 15, 2006 | 01:48 PM
NstyLT1's Avatar
what is the clearance like with those mufflers?? cuz im thinkin about getting those for my longtubes and x pipe..
Old Feb 15, 2006 | 02:09 PM
blkchevyz's Avatar
when i switch my clearnce didnt change one bit.
if i remember the flowmasters were the same height if not smaller in size as the bullets
LT14LIFE
Feb 9, 2015 09:35 PM
alphaauto
Jan 22, 2015 08:02 PM
Queens94z28
Nov 20, 2014 06:03 PM
RedLineRev
Jan 23, 2003 03:51 PM
