my timing chain broke (pics inside)
Old Apr 20, 2004 | 09:03 AM
  #16
1994TransAm's Avatar
wow
let me know if you need any parts...
i have the timing cover off a 94 LT1 for sale!!!
5 $
Old Apr 20, 2004 | 10:25 AM
  #17
turbo_Z's Avatar
its almost impossible not to have some bent valves... sorry to say.
Old Apr 20, 2004 | 10:32 PM
  #18
ChickenScreamer94's Avatar
I agree. Especially at high rpm. My friends old eclipse was idling when his went, he had to redo the whole motor (well timing belt, whatever)
I do not think it ismart to do a cam and head swap on a 150K mile motor.
Old Apr 20, 2004 | 10:43 PM
  #19
Cwynn's Avatar
Timing chain should have been replaced period. It doens't matter how many miles the car has in this case.
Old Apr 20, 2004 | 11:21 PM
  #20
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
Go with an extreme duty LT4 timing chain so it never happens again... hope you didnt mess your car up too bad.....
Chris
Old Apr 21, 2004 | 01:35 AM
  #21
TexasTechTA's Avatar
My bros chain broke on his bolt on 94 TA although he had just doen 1.6 RR's and no valve springs and his broke and he had bent valves and had to sand his pistons down where they hit, kind of ghetto in my opiion, but it ran fine after it.
Do timing chains on our cars need to be replaced if it is justa bolt on car? I though they lasted forever, is this a common problem for lt1 cars?
Old Apr 22, 2004 | 04:17 PM
  #22
LT1TONY's Avatar
I broke a stock timing chain on my old stock motor. I too had bent valves. Before pulling the heads do a leak down test to determine if you have any bent or not.
Buy the Extreme LT-4 Chain and upgrade the bottom crank gear with the slight oversize one that Cloyes makes for this. It will really take the slack out.
Old Apr 22, 2004 | 04:26 PM
  #23
was the motor salvagable?
Old Dec 28, 2004 | 12:12 PM
  #24
hotrod18_69's Avatar
Re: my timing chain broke (pics inside)
Originally Posted by LT4Firehawk
You really need to pull the heads and at least check everything before trying to start it up again. If you got bent valves/pushrods you could do serious piston damage by starting it up after just changing the chain.
Yes you need to check for valve/piston slap. My buddies formula did this last summer. And when i took the heads off he took out 3 valve's and pushrods, nicked up two pistons pretty good. So don't over look it, it needs to be checked. More than likly at that RPM, u bents some.
Brad
Old Dec 28, 2004 | 03:18 PM
  #25
Flmac02Z's Avatar
I would not recommend doing a cam swap on that high milage of a motor unless you rebuild the bottom end first...to me it's just too much of a risk of spinning a bearing...
~Kevin
Old Dec 28, 2004 | 03:59 PM
  #26
30696bird's Avatar
Pulled up an old thread to give advice??? I'm sure he has the problem solved by now.
Old Dec 28, 2004 | 10:41 PM
  #27
1racerdude's Avatar
Broke chain=bent valves.......
Old Dec 29, 2004 | 11:09 AM
  #28
QUASARBLUEZ28's Avatar
Chances are very very slim that there is no damage to the valve train . You odds are probably better winning the lottery. Tear it all down unless you don't have the time to do it right, but you have the time to do it twice.
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
