my times at milan dragway last night....
I have a 95 t/a 6 spd with these mods...
cai, mac mid headers, computer tune by madz, deleted cat and hooker exhaust. I have 342 gears and left everything except the spare tire in the car.
My best run was a 13.68 at 102.43 mph with a 2.0x 60ft. time. I'd like to do a cam or heads or 4:10 gears this winter (finances dictate the "ors" instead of "ands")
What do the knowledgable feel would be my best gain for the buck? The smell when I left the track last night screams that a new clutch is coming soon too!
p.s. it was 80 degrees when I was running and I never let the car cool down.
Thanks for any advice.
Re: my times at milan dragway last night....
Get some good tires and a clutch to put that power to the ground. Get that 60 down and you'll be doin pretty good. Stay with the 3.42 gears the 4.10s will just break...unless you want to trade gears...hehe.
Go to Driveline-Solutions and get 4.10's installed. The new GM Gears Scott uses are just as good as your OEM 3.42, and he has great prices, and everyone in Michigan recommends him.
I ran the exact same time as you but my 60ft was a 2.06. I have the mods in the sig plus weight reduction when I ran that time. (car weighted 3200 w/me in it) My only advice is some drag radials. I am waiting for some cold weather to try for better times.
I don't see where the need to tell someone to "learn how to race" when I see nothing about running good tires and cutting 2.0's...which is not bad at all.
What should he cut on stock tires and minor mods...a 1.6X 60'?
Don't YOU cut 1.6X 60-foot times on stock tires and minor mods??
I appreciate you're reply cantonracer! I was confused by my need to "learn how to race" when I was cutting 2.0 60' times on non drag radial tires. I assumed it wasnt meant as negative though. My main issue though is what will give me the "largest gain". It seems I could do any one of these mods for under a grand (including the new clutch) but I'm affraid a new clutch, sticky tires and a regeared stock rearend is just begging for breakage. I really plan on doing the "right" rearend eventually so maybe I should ask what gains can be expected by just doing a cam on stock heads with my 3:42's for now?.
I do plan on at least 4:10s or higher when I do the rearend whether now or later.
Z28Wilson
Aug 1, 2002 04:27 PM
z28projects4ever
133
Jul 26, 2002 01:54 AM
Darth Xed
15
Jun 28, 2002 11:51 AM
