Is this my starter?
Old Mar 10, 2003 | 01:06 PM
James3219's Avatar
Question Is this my starter?
When my car is cool, like has been sitting over night, it starts up fine. But if I have driven it any distance and try to start it up while the car is warm or hot, it does not want to start. It's almost like its not getting any juice to turn the car on. I know my battery is fine, I just had it tested maybe a month ago. What do you think it could be?
Old Mar 10, 2003 | 01:14 PM
RedRyder518's Avatar
I would say yes...If I had to guess why, it seems like that since you had the car running for a while, the starter is getting heated up and when you try to restart it, maybe there is too much resistence built up in the starter due to te heat
Old Mar 10, 2003 | 02:34 PM
x7x7's Avatar
Sounds like starter heatsoak.
Old Mar 10, 2003 | 03:33 PM
James3219's Avatar
Whats that, am I gonna need a new starter. Or can I fix the problem?
Old Mar 10, 2003 | 03:42 PM
joeSS97's Avatar
You could fab up a heat shield.I believe you can buy tape that might do the trick.Its worth a try.
Old Mar 10, 2003 | 06:15 PM
James3219's Avatar
TTT, anyone else?
Old Mar 10, 2003 | 06:23 PM
x7x7's Avatar
It doesn't look like you have headers. So I'd say replace the starter. If you have headers you may want to look into using a heat resistant wrap to cover the starter or get your headers coated.
Old Mar 10, 2003 | 06:49 PM
James3219's Avatar
No, I don't have headers. I may still look into the heat wrap.
Old Mar 10, 2003 | 07:34 PM
kcz28's Avatar
i am buying a stater tommorow where can i find a heat wrap
or what type of tape do i use
Formula Steve
Sep 19, 2023 08:31 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
4586
Aug 18, 2015 07:08 AM
realistyc
Jul 28, 2015 07:32 PM
