Is my rear sway bar the same as the panhard bar?
Old Mar 6, 2003 | 12:14 PM
96cam4ro's Avatar
I've bent the bar that they have to take off in order to do a gear swap (right between the axle and the muffler - goes from side to side). Is this the rear sway bar or the panhard bar? thanks.
Old Mar 6, 2003 | 12:20 PM
scamaro's Avatar
if the bar goes STRAIGHT horizontaly left to rightand is round then it is the sway bar. if it starts on the passenger side and goes DOWNWARD at a slight angle towards the drivers side, and looks like a stamped ( U shaped) piece of metal then it is the panhard rod. hope this helps. oh if it is the panhard BMR motorsports makes a great replacement that is a t a VERY good price.
Old Mar 6, 2003 | 12:33 PM
stik6shift93's Avatar
Sounds like you're talking about the panhard bar.
Old Mar 6, 2003 | 03:38 PM
96cam4ro's Avatar
From the above description, it's the panhard bar (u shaped & straight). What does it do? I've noticed wheel hop when I'm turning right.
Old Mar 6, 2003 | 03:56 PM
It keeps the rear end centered under the car.
Your wheel hop could be just from the posi locking up. That is normal in a tight turn with a little power.
HarleyZ28
Oct 5, 2015 06:23 AM
96SilverRam
May 5, 2015 09:56 PM
thenewkid
Apr 12, 2015 07:42 PM
thenewkid
Nov 27, 2014 09:41 AM
