my POS is driving me insane! pt.2
Old May 29, 2003 | 02:29 PM
CamaroRob97's Avatar
okay well if ur wonder what part 1 was all about do a search in the topics and type in my POS is driving me insane...any who i did a few things since then but none seem to have worked, i disconnected the pos. terminal and with the neg. terminal still connected to the battery touched them to clear the whole computer: nothing same thing, the i check all my spark plugs to make sure they weren't fouled out: nothing again they're fine, then i thought well maybe its the injectors, so i took a test light to #2 and #4 and they have power, so now im down to three last things... etheir since my speedometer is pegged out @ 150mph maybe (abnd i doubt it) but it has something to do with my gas gauge and may be the tank is completly empty, evan though it reads 1/2 tank, or its my ignition module, which i check with my work (Autozone) and as luck may have it we can't check those ones and my last resort is to take out a spark plug have someone try and crank it over just to confirm that i am getting spark.... so im up for anyother suggestions or hints/tips
thanks for checking this post out!!!!!!
Rob
Old May 29, 2003 | 03:32 PM
joeSS97's Avatar
In a no start situation,the first things to check are fuel and spark.Do you hear your fuel pump go on?Check the pressure.If thats good start checking for spark....hope that helps.
Old May 29, 2003 | 09:27 PM
ttt
mr28
Apr 20, 2016 05:44 PM
warmeck
Feb 5, 2015 11:04 AM
NewsBot
Jan 8, 2015 11:29 PM
mr28
Nov 23, 2014 11:11 AM
