my oil is white
Old Aug 2, 2004 | 10:21 PM
st_paul's Avatar
my oil is white
this is what happened:
i just put in new heads, cam, electric water pump, timing cover, switched to vented opti, and new timing chain. i sealed the timing cover to the oil pan with rtv. it started up right away but since the valves weren't adjusted i didn't let it run for long, maybe 3 minutes. when i shut it off i discovered oil all over the ground maybe 2 quarts. it had leaked out of the timing cover to oil pan seal. when i drained the oil it was white. what happened?
Old Aug 2, 2004 | 10:23 PM
madwolf's Avatar
Re: my oil is white
If the oil is white, it means it's mixed with coolant. You may have blown a head gasket or who knows...
Old Aug 2, 2004 | 10:24 PM
Re: my oil is white
Sounds like water in the oil.
Old Aug 2, 2004 | 10:30 PM
Spinner's Avatar
Re: my oil is white
Agreed. Water or condensation
Old Aug 2, 2004 | 10:38 PM
n2ceptor's Avatar
Re: my oil is white
I concur....
Old Aug 2, 2004 | 10:42 PM
ibanez6rg's Avatar
Re: my oil is white
Sounds like you didn't do a few things right.
Old Aug 2, 2004 | 10:47 PM
st_paul's Avatar
Re: my oil is white
i am hoping that it is just because i didn't drain the oil when i took the heads off but how much coolant gets into the oil when you take the heads off?
Old Aug 2, 2004 | 10:54 PM
ibanez6rg's Avatar
Re: my oil is white
Not to bust your bubble, but, coolant + bearings =
Did you drain any of the coolant before you took the heads off? Seep down through the cylinder walls?
Old Aug 2, 2004 | 11:18 PM
st_paul's Avatar
Re: my oil is white
yeah the coolant was drained before i took the heads off. it started up fine and run great for at most 3 minutes then i shut it off, i just wanted to see if it would start up. i refilled the coolant with just water before the intial start up.
Old Aug 2, 2004 | 11:22 PM
Re: my oil is white
Not that much, if any, if you drained the coolant first. I wouldn't be betting on that.
mr28
Apr 20, 2016 05:44 PM
dylan1303
May 22, 2015 12:24 PM
captcorvette
Mar 7, 2015 12:37 PM
NewsBot
Dec 24, 2014 11:05 PM
