My Next Mods HP/TQ Thoughts
Old Dec 11, 2003 | 09:36 AM
whontime's Avatar
Ok, most of my mods are in my sig. I have Lloyds Heads and the 227/233 XE cam. My latest dyno numbers were 351hp/333tq. The numbers are a little low, but I just had the car back together that day and it still needs some fine tuning. I am considering a couple of mods to squeeze a little more power out of it. I really want to get around 370-375 if possible. Here are the plans:
I currently still have the STOCK rear exhaust section on the car. Jet Hots, Hooker Y-Pipe and then stock exhaust with a crappy Flowmaster muffler in it. I should see some increase by going to the Hooker catback, correct? Any guesses on what kind of rwhp increase I would see? I imagine that this would be a worthwhile mod. Or..... Should I just keep the rear section as it and have a cutout installed between the Hooker Y-Pipe and stock rear section?
Next, I am considering buying the ASP pulley/balancer combo to try to get that extra bit of power. Is anyone running this pulley? Are the gains worth $145?
One more thing, I haven't done the TB bypass. Should I? I have the 160 stat and its pretty cold here right now.
I also have a air foil just laying around, is it worth installing or not? I wouldn't buy one, but since I have a free one it may be worth a try.
Thoughts/comments are welcomed. I would really like to improve my numbers a little. The car is running lean and the spark advance was at 46--- is this too high?
Old Dec 11, 2003 | 10:36 AM
94GrayV6's Avatar
Umm, do you have a CAI? Thats a good 10-15 rwhp right there on your car. Regarding the catback thing...it would definitely be cheaper and worth a few more ponies to do a cutout, but I'd go with the hooker. I think when all is said and done you could be up to 380ish rwhp.
Old Dec 11, 2003 | 11:32 AM
whontime's Avatar
Yes, I have a Moroso CAI. I just forgot to list it. I have found a dyno tuner close to my area so I think that I am going to go that route with my tuning here pretty soon.
Old Feb 16, 2004 | 01:51 PM
GetaZforgetGT's Avatar
I think you would see some gains from a Catback system or a cutout. You can get a used setup for very little money but even a new one isn't bad.
Your loosing some of your exhaust flow due to the stock pipe diameter.
Old Feb 16, 2004 | 02:30 PM
Fastbird93's Avatar
Definitely go for the exhaust or cut out.
NICE NUMBERS by the way. That's pretty impressive. What's the lift on that cam?
R@mpage
Apr 20, 2015 10:02 AM
alex5366
Mar 27, 2015 03:30 PM
maybe2fast
Mar 13, 2015 11:48 AM
