My MAC single cat headers are on!!!
Old Mar 23, 2004 | 07:17 PM
  #16
stereomandan's Avatar
I have to agree about the sound quality. Awesome. Super deep. Not hollow.
Did you try it at all without punching the whole in the catalyst?
Dan
Old Mar 23, 2004 | 08:48 PM
  #17
Steve0's Avatar
Originally posted by glenn
SteveO,
I'm putting MAC's on my 94 right now. I also bought them used. What kind of washer did you have to put in the AIR fittings to make them seal?
Thanks,
Glenn
If you look into the origional manifold youll see a lip that the air tube seats on. I took my old manifolds to Ace Hardware and just looked through the washers till I found one that fit down in the threads pretty snuggly. I believe it was a 7/8ths inch outer diameter washer, with a 3/8ths inch inner diameter. I also believe I used 4 washers inside each air fitting. You dont want the outside diameter of your washer too small because it may fall into your primary when you drop it in the fitting.
When you install your air tubes they should fit snuggly, with no play if you jiggle them up and down. Hope that helps.
Steve
Old Mar 23, 2004 | 10:02 PM
  #18
glenn's Avatar
SteveO, thanks for the explanation, I understand what you did.
Thanks,
Glenn
Old Mar 24, 2004 | 09:56 AM
  #19
Got-LT1?'s Avatar
Hey Sterioman,
Congrats on the install... I am planning on doing the exact same thing very soon... 94-95 Mac mids on my 96... One quick question for ya. Did the 02 sensor wire reach the passenger side 02 sensor? or did you need an extension? Because on the 94-95 model the sensor is much lower?
Let me know how you handled this?
Old Mar 24, 2004 | 11:07 AM
  #20
Actually, you don't need an extension for the passenger side, but you DO need one for the drivers side. I ordered a 12" 4 pin flat extension from LS1speed.com
You also need to get different AIR adaptors. I called Jet-Hot and got what I needed, but MAC should know what you are talking about. Tell them you have a 96-97, but are installing the '94-'95 headers. They should know what to do. It's just a threader male to male adaptor. It replaces the ones that are on your manifolds now.
You will also need:
Antiseize compound for the header bolts, O2 sensors, and spark plugs
You also need Permatex ultra copper RTV to help seals the slip tube primary.
Have fun, and I hope you are leak free.
Dan
Old Mar 29, 2004 | 10:07 AM
  #21
Fast Caddie's Avatar
Dan
yea, i had the hooker and MACs for about a year before punching the cat. It still sounded good..... but after the !cat mod it was even deeper, louder, and pulsated harder...like a mild "pop" or boom sound. IMO it made it sound a lot better. But now the exhaust smells worse
Old Mar 29, 2004 | 10:22 AM
  #22
Yeah, soon I'm going to be welding up a bolt-on bullet muffler that I can swap in place of the cat. I'm worried that even though the cat is a high flow cat, it it still restricting too much exhaust flow.
The straight thru bullet muffler will fix that. I'll see how I like it. Maybe the smell will make me go back to the cat.
Dan
Old Mar 29, 2004 | 12:40 PM
  #23
ZZtop's Avatar
That was me doing the flyby...
That car sounds great, not too loud, not too quiet! I am definitely getting MAC's in the future, but I cant stay away from loud, so I will be running my cutout open 24/7 jsut like I do now. Boy that should be loud!
By the way Jason, the car is in the shop getting new head gaskets and springs good to 0.600 lift so I might get to do the 1.7's first But I really need those headers to make it worth it.
Old Apr 1, 2004 | 05:08 PM
  #24
Sounds good bro... get that ol' girl running good. We need to try to get to the dyno soon so we can see what the 1.7s do for us.
And when we gonna do some flybys again?
MDZ28
Exhaust System
Jun 2, 2015 09:48 PM
Pig Pen
Parts Wanted
Apr 30, 2015 08:41 AM
Russ95Z28
Apr 23, 2015 01:55 PM
Midnight_Z
Parts Wanted
Apr 3, 2015 12:46 AM
Carson96Z28
Aug 28, 2002 05:23 PM
