my lt1 plan...
Old Jan 20, 2008 | 01:17 PM
black95maro's Avatar
my lt1 plan...
so i did some research and this is what I came up with, for building up my lt1 before i put it in...
-CC305 cam (cca-07-305-8)
-Crane gold race rrs 1.6 (crn-10758-16)
-Comp valve springs (cca-26-918-16)
-Comp retainers (cca-787-16)
-Comp valve locks (cca648-16)
thats all i have for now. The rockers are on they're way. any opinions on this?
Old Jan 20, 2008 | 01:59 PM
96' Formula WS6's Avatar
Are you talking about just those mods. Or are you talking all the bolt ons and those mods. Just wondering, if not you should consider doing the boltons. Just my .02
Old Jan 20, 2008 | 02:12 PM
jammer94's Avatar
looking good on the valvetrain tip have you invested in changing out the stock oil pump driveshaft this should be changed whenever doing a cam swap as the factory piece has a plastic retainer on holding it.
Old Jan 20, 2008 | 06:17 PM
this is just what i've somewhat hammer down as far as the valvetrain. yes i will have headers and I'll use the k&n cai. the posi rear is already in with a one piece ds. what other kinda supporting mods can i do? and jammer, i have a mellings high volume in the v6 now, wondering if it will swap over? either way thanks for the heads up. any other opinions??
Old Jan 20, 2008 | 07:16 PM
jammer94's Avatar
i am not sure if it will swap over more then likely it might not if you do buy a pump you can buy the melling 10550 which is the new version and i forgot the # for the pickup....
Old Jan 25, 2008 | 09:50 PM
sn8ke eatr's Avatar
looks good im actually running an identical setup. have it tuned for best gains
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
