My Lt1 Just Died On Freeway
Old Jun 25, 2004 | 02:41 AM
dabez1's Avatar
I was entering the freeway and since there was no cars around i floored it !WOT! When it was about to shift into second Theres a big bang and the car turns off, the sound came from somewhere in the hood. I put it on nutral and just park it on a gas station. After wondering what had happened i turned it on again and it started but it sounds REALLY bad, like metal hitting metal, maybe its the piston or something. This SUCKS, i left my car on the gas station and having someone take a look at it 2morrow.
What could of caused this?
Old Jun 25, 2004 | 02:54 AM
Zeueses 97 RamAir's Avatar
threw a bearing
Sounds Like you threw a bearing. Sorry never have butmy freinds ls1 did the same thing.Kinda of strange coming from a lt1 usually there hard to blow.
Old Jun 25, 2004 | 03:00 AM
dabez1's Avatar
A bearing?? How much would this caused to fix? any more info on this?
Old Jun 25, 2004 | 05:53 AM
IDOXLR8's Avatar
Your best bet would be to remove your oil pan to see if you can see anything. It can be alot of different things.
Old Jun 25, 2004 | 06:34 AM
scoobysnax83's Avatar
If it sounds like rocks or golf ***** then it is mostly likely a spun bearing...
F'n1996Z28SS
Aug 23, 2023 11:19 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
Ricardo
Nov 29, 2014 10:58 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
