My LT1 dyno results...Not too shabby, I think.
Old Mar 5, 2006 | 11:48 PM
  #16
Cerwin Vega Fan's Avatar
Re: My LT1 dyno results...Not too shabby, I think.
Not bad at all, I love the white Z28 Vert. Look like mine almost just with less miles (damn the long trips to school).
Old Mar 6, 2006 | 01:46 AM
  #17
93turbo5oh's Avatar
Originally Posted by Zigroid
thats a strong running LT1, congradulations.
you should trap around 105-106. E.T. would depend on traction. maybe low 13s?
in mustang land thats enough mph for 12.60-12.80s.
Old Mar 6, 2006 | 02:38 AM
  #18
madwolf's Avatar
Originally Posted by Jeremy95TA
However, not trying to put a damper on things, but with a 6-speed I think your numbers are a bit low... I think that your mods should put you at around 315-325 rwhp.
How? That's getting into cam range numbers. His numbers are quite good for what he has.
Originally Posted by 95z28 -quicksilver
Yeah lean it out to about 13:1 and you will see 10-15 rwhp.... Still pretty good numbers though. Looks like the 1.6rr's pushed ya over the edge
Not quite unfortunately. Probably not even 2-3 RWHP out of leaning it out more.
Great numbers!
Old Mar 6, 2006 | 05:49 AM
  #19
CamaroRob97's Avatar
Nice no.s bro! Seriously for a 95 LT1 with 73k original miles NOW its time from some head porting and a nice cam to put those 1.6RR to work
Old Mar 6, 2006 | 06:29 AM
  #20
wrd1972's Avatar
Thanks for the input all.
I dont plan on porting the heads and installing a cam until I need a reason to have to tear the engine down. It is has reached my expectations already at this point and I am verry happy with the way it runs.
So if the opti goes or somthing starts leaking bad then I plan on at least going LE2 port job and LE1 cam. I dont want to rev the engine to 6.5K (LE2 cam) because I prefer to have engine longevity and still decent gas mileage.
The car currently launches pretty good on these street tires, the big thing hurting 1/4 mile times will be my weight since I have the heavy vert and some hi-fi in the trunk. I might be able to throw some drag slicks on and sneak a few runs past the 10-bolt rearend.
If I can hit some mid 13's on street tires and some low 13's on drag slicks I will be very pleased. The current goal was to be able to evenly compete with a stock LS1 and maybe wack a few in the process. It appears that this has been accomplished.
Plus needless to say if this engine did get heads and cam it would be a beast.
Old Mar 6, 2006 | 08:06 AM
  #21
GreenZLT1's Avatar
excellent numbers! I would like to get my car to 300 rwhp also..
Old Mar 6, 2006 | 11:22 AM
  #22
The Superflow dyno can be operated in a couple of different modes, if I recall the info from an article in Hot Rod magazine about 1.5 years ago. One of the modes is basically a Dynojet inertia emulation, and produces similar results. It can also run in Eddy-current mode, similar to a Mustang. You need to ask the dyno shop what program they used.
"STP" is standard conditions (29.92"Hg, 59degF, 0% RH), which produce a shade more HP than "SAE" conditions (29.235"Hg, 77degF, 0% RH). Not unusual to see.
I would have expected a bit more gain in leaning out from 11.8:1, but I'm not going to argue with the programmer.... he knows what he put into the program and why he did it.
Old Mar 6, 2006 | 02:08 PM
  #23
seawolf06's Avatar
Wouldn't the 4.10's account for a little hp loss as well? It thought that higher gear ratios cause your hp to drop slightly on a dyno.
Old Mar 6, 2006 | 02:10 PM
  #24
wrd1972's Avatar
I would tend to think that a 1/1 ratio would be more efficient than a 4/1 ratio.
Based on that logic a 3.42 would have less loss than 4.10.
I think I will differ here.
Old Mar 6, 2006 | 04:44 PM
  #25
truedualws6's Avatar
Originally Posted by wrd1972
All the sheets I have are posted. The sheet states STP corrected.
Maybe someone can educate me on what all the numbers reall say.
It was my understanding that these were corrected numbers for temps, pressures & altitude.
You can search for a lot of information regarding the various testing standards
such as SAE, STD, and STP. The closest simple comparison I have come up
with is that SAE numbers are about 4% lower that STD/STP numbers. STD and
STP are the same correction factor.
My first pre baby cam dyno runs were done on a Superflo dyno with STD correction
and I was at 310 rwhp (297.6 SAE). Just reduce your numbers by 4% for SAE.
Old Mar 6, 2006 | 04:55 PM
  #26
2000GTP's Avatar
Nice numbers.
Old Mar 6, 2006 | 05:13 PM
  #27
IllusionalTA's Avatar
Very Nice #'s Smooth curve as well.. If your happy that's all that count's..
Old Mar 6, 2006 | 05:39 PM
  #28
Evil Eric's Avatar
Awesome numbers for a bolt on car, looks like you leaned out a hair in the upper rpms.
Old Mar 6, 2006 | 07:28 PM
  #29
wrd1972's Avatar
I must be confused about what is rich and what is lean.
I though as the A/F number dropped the car was running more rich.
Someone please explain this to me.
Old Mar 6, 2006 | 07:49 PM
  #30
It leaned out when he got out the gas.. otherwise he's running lil fat.not that bad .
