Is my LT-1 dead?
Old Dec 22, 2003 | 03:08 PM
  #16
Stormman's Avatar
Originally posted by HesterZ28
the poping sound coming from the alt? maybe your alt went bad and isnt charging your system. your car will misfire and sputter and not run on low voltage
I tried to jump start it today with my Caddy. She cranks over no problem. Interestingly enough the oil pressure gets up there while cranking. When I turn the key I hear the "whine" from the fuel pump. I guess its still either fuel pump or fuel pressure regulator switch? or the opti. Not much of a choice considering they are both big jobs.
Any other thoughts out there?
Thanks again...
Old Dec 23, 2003 | 07:33 AM
  #17
IslandZ's Avatar
Here's what happened to me, the rotor in the opti broke of and was floating in there (this happened to me twice with 2 different opti's!). It sounded like pebbles and of course the car wouldn't start. When it died I got a bunch of backfires, and pretty much like you are describing. My money is on the rotor in the opti, but better replace the whole unit. And it isn't that hard to do, shouldn't take more than 2 to 3 hours.
Old Dec 23, 2003 | 08:21 AM
  #18
94 Roadhog's Avatar
I agree with IslandZ
Dave B
Old Dec 23, 2003 | 09:30 AM
  #19
faded93bird's Avatar
Well in your sig it says you need to fix you stumble. I would bet the opti gave up on ya, all the problems you described could be opti caused.
Old Dec 23, 2003 | 03:56 PM
  #20
Stormman's Avatar
Yea now that the car doesn't run, I tend to agree with you, especially after all the sensor changing I have done.
Old Dec 28, 2003 | 02:47 PM
  #21
Stormman's Avatar
Well I tried to jump her again. This time I got a bad fuel smell so I assume the pump is working.
Thought I'd bring this thread back to like in case some of the experts didn't see it the first time.
Anyone else have something to offer please do.
Old Dec 28, 2003 | 02:55 PM
  #22
texasTA's Avatar
I hate to sound like a broken record, but I would bet it was your opti rotor. Those items (opti, rotor, etc...) CAN just go all of the sudden. My brother's heads/cam and full exhaust 96 Z28 had an opti go out. It made the same kind of violent backfires. Took us about 3 hours to replace and viola, problem solved. Good luck
Old Dec 28, 2003 | 03:33 PM
  #23
bruecksteve's Avatar
Since it's a '94 and probably has quite a few miles on it, the opti is my guess too. Did the check engine light come on?
Old Dec 28, 2003 | 04:21 PM
  #24
95THNDR's Avatar
I had a similiar problem on my car and it was the opti. Check the coil, wires and plugs first. I have seen the coil do strange things including that popping sound.
Scott
Old Dec 28, 2003 | 05:20 PM
  #25
hsyr's Avatar
I highly doubt its an exhast leak.
Old Dec 29, 2003 | 08:07 AM
  #26
Stormman's Avatar
Would anyone know what the shop manual says the labor in hours should be for the opti? I spoke to mechanic this a.m. says 3 hours alone for water pump. I'm trying to guess how much this is going to cost.
Old Dec 29, 2003 | 01:54 PM
  #27
BigRich's Avatar
when did you add the "things to do: fix stumble," to your sig?
might be the opti
might also be a burned wire on your headers, though the car should start up even with a burned wire.
Old Dec 29, 2003 | 04:28 PM
  #28
Stormman's Avatar
I'm looking online to order the parts for the opti. I went to gmpartsdirct.com. What completes the opti change? cap rotor bolts, distributor gear? anything else?
This is what I found so far:
GM PART # 10457702
CATEGORY: Ignition Distributor
PACK QTY: 1 CORE CHARGE: $0.00
GM LIST: $652.46
OUR PRICE: $326.23
DESCRIPTION: DISTRIBUTOR/OPTI-SPARK
Fits 92-94 Corvette and 93-94 Camaro, Firebird and Trans Am. Without vent.
GM PART # 10457735
CATEGORY: Distributor Caps
GM LIST: $377.96
OUR PRICE: $188.98
DESCRIPTION: CAP KIT(only 2 pc cap ,rotor and bolts)
Old Dec 30, 2003 | 07:43 AM
  #29
IslandZ's Avatar
Call Jason Cromer, he has lower prices and the shipping is not as high as gmpartsdirect.
Dont get the cap only, change the whole unit.
Old Dec 30, 2003 | 08:09 AM
  #30
Stormman's Avatar
Thanks eveyone for your thoughts & answers.
