My lights are huanted!!!
about a month and a half ago i was driving and my right fog light just went out. i though nothin of it. then about two weeks ago my left headlight went out. and a week after that my left brake light/turn signal went out!!!
By now i was pretty pissed off. so i popped my hood and just lightly tapped the top of my headlight and it came on!!! it went back off in the cold a few times but i just hit it again and it came on. now it never goes out!!
same thing with my fog light! i punched it, and it came on and has never went back out!
And my brake light started working a few days ago too! i must have went over a bump or something.
has this happened to anyone else? whats wrong?
Check all your ground connections.
Specifically the two that connect to the rad shrowd ontop. You'll see one on each side of the rad just inside where the hood support bumpers are.
Remove, clean very well, and reinstall with new ends.
If that doesn't work, check the ground strap that connects to the coil as well as the one on the block.
dluna333
15
Mar 13, 2015 12:30 PM
squarehead
Jan 15, 2015 07:02 PM
