My LE2 parts list complete?
Old Feb 13, 2007 | 01:17 PM
z28_theantirice's Avatar
Here is a list I have made in preparation for an LE2 install, I was just looking for some feedback as to whether or not I have most everything covered.
Old Feb 13, 2007 | 01:27 PM
street demon2k3's Avatar
dont forget the top/bottom end gaskets. oil pan, intake manifold, valvecover, water pump, timing cover, opti seals, ect..
I have a full list for my build as well but I got it at home somewhere.
Old Feb 13, 2007 | 01:28 PM
add an electric water pump to that list
Old Feb 13, 2007 | 01:29 PM
mark94's Avatar
Plan to use stock lifters?
New intake & header gaskets. Are these included in your Cam Swap Package?
Old Feb 13, 2007 | 01:30 PM
all of those minus the oil pan gasket comes in the cam swap gasket package
Old Feb 13, 2007 | 01:31 PM
Z-RATED94's Avatar
I'm not sure on the injectors you have picked. I know that many prefer the SVOs. It's getting late for me (work third shift) so hopefully others will chime in on the brand you have selected. Other than that I can only comment on your choice of pushrod lenght. You won't know what you need until you check. I'm probably missing something else, but I'm sure others will speak up.
Old Feb 13, 2007 | 01:34 PM
not sure on the lifters yet, my original stockers have 56k on them. And my header gaskets only have 2k on them so I think they will be ok
Old Feb 13, 2007 | 01:53 PM
2000GTP's Avatar
Do you have copper or aluminum header gaskets? If you are using the Fel-Pros, you will most likely have to replace them. If you want to use the Cloyes double roller timing set, you will have to switch over to the electric water pump. Otherwise, the LT4 ED timing set would be another option. I wouldn't necessarily jump on pushrods yet either. You may want to get a pushrod length checking tool and find out what size you need that way.
Old Feb 13, 2007 | 03:08 PM
roadtrip120's Avatar
Thats a short list, and some of the parts you could find cheaper at different venders
Here is the list i have for my customers, LE1/2 400rwhp everytime!
Timing Set Pro Gear
Lifters Gm ls7
Head Gaskets Felpro
Head Bolts ARP
Heads LE2
Pushrods comp
Rocker Studs ARP
Guide Plates GM
Rockers Comp pro mag 1.6
Valve Stem seals
Core Heads Gm
Valve Springs Comp
Retainers Comp
Keeplers Comp
Valve Cover Gaskets Felpro
Intake LE2
Throttle Body bbk58mm
Injectors SVO 42lb
Under Drive Pulley March
Belt Gator
Core Intake Gm
Headers / Y-pipe Pace Setter
Camshaft BRE
Fuel Pump Walbro
TQ arm mount Poly
Trany mount Poly
Park Plugs NGK
Plug Wires MSD
PCM ODB I conversion, pcmforless mail order tune
Opti GM
Oil Castrol
Antifreeze
Silicone
Shop Rags
Parts Cleaner
Fuel Filter
Assembly Lube
Thread Sealant
Intake Gaskets
O2 Extensions
CSI electric WP
Old Feb 13, 2007 | 03:51 PM
sworaz
Guest
Posts: n/a
Lloyd told me to go with the 37lb Delphi injectors. You can find them at Racetronix.com for 294 shipped. Good luck i'm in the same boat.
Old Feb 13, 2007 | 04:42 PM
How many LT1 guys are actually using the LS7 or the GMPP LSx lifter ?
Old Feb 14, 2007 | 01:22 AM
gemballa996's Avatar
i just ordered the gmpp lsx lifter for my lt1, but they're on a 2 week back order from sdpc.
Old Feb 14, 2007 | 02:00 AM
same here, back ordered from sdpc
Old Feb 14, 2007 | 07:32 AM
Z-RATED94's Avatar
My mistake then. I was just trying to point out that some injectors are better than others.
Old Feb 14, 2007 | 10:14 AM
Any idea if the height is the same as the LT1 lifter? Would it be worth the trouble and money to run them on an stock blocked LE2 car?
