My injector ohms readings
Old May 4, 2004 | 10:40 PM
$hawn's Avatar
I'v read that the injectors ohm readings should be 12ohms, mine all were 13ohms, whats this mean. Is that exceptable?
Old May 4, 2004 | 11:11 PM
If they were all 13, I would say you are ok. May be a slight meter deviation. Did you check the base resistance or "zero out" the meter by touching the leads together before you started? Also a lower scale might give you a more precise reading. Your readings might have been rounded up to the next whole ohm.
Old May 4, 2004 | 11:16 PM
96TurboTA's Avatar
Also, some of the less expensive meters aren't all that accurate.
Old May 4, 2004 | 11:17 PM
$hawn's Avatar
It was awhile ago that I did it, pretty sure I touched the leads together to zero it out. I'll have to check them again with the meter set at a different/lower setting and see what I come up with. Thanks
Old May 4, 2004 | 11:53 PM
VeryBad's Avatar
They are fine, usually run 11.5 - 13 ohms depending on the coil temperature.
Gordon
WitchHunter Performance
Old May 5, 2004 | 12:14 AM
Lt1t56's Avatar
Good question and Iam not trying to steel this thread but today I checked all my injectors ( put the ohm meter leads on metal prongs sticking out of injectors ) and all my injectors read 0
Old May 5, 2004 | 08:15 AM
If your car is running, you must have had your meter set up wrong. Maybe you had it on the volts scale when you should have had in on ohms.
Old May 5, 2004 | 08:46 AM
Eff's Avatar
Eff
Or Maybe you were touching the leads togather
nophix
Nov 30, 2014 10:26 PM
ChameleonGreen
Sep 2, 2002 05:15 AM
Omega9
Aug 2, 2002 12:33 AM
z28projects4ever
9
Jul 16, 2002 07:48 PM
