My injector ohms readings
If they were all 13, I would say you are ok. May be a slight meter deviation. Did you check the base resistance or "zero out" the meter by touching the leads together before you started? Also a lower scale might give you a more precise reading. Your readings might have been rounded up to the next whole ohm.
It was awhile ago that I did it, pretty sure I touched the leads together to zero it out. I'll have to check them again with the meter set at a different/lower setting and see what I come up with. Thanks
They are fine, usually run 11.5 - 13 ohms depending on the coil temperature.
Gordon
WitchHunter Performance
Gordon
Originally posted by Lt1t56
Good question and Iam not trying to steel this thread but today I checked all my injectors ( put the ohm meter leads on metal prongs sticking out of injectors ) and all my injectors read 0
z28projects4ever
9
Jul 16, 2002 07:48 PM
