Is my IAC motor dying?
Old Jun 21, 2003 | 12:04 AM
ChickenScreamer94's Avatar
I have idle problem only when the engine has been running for more than 30 mins and have been sitting in traffic in gear. My rpms keep getting lower (like 450 rpm) and it then jumps up to 700 or 800rpms and goes back to 500ish. I just cleaned the IAC motor assy. and it still does this, just not as bad. Is my IAC motor taking a ****? Could this be something else? It idles perfect except for this thing.
Old Jun 21, 2003 | 12:18 AM
Fatdog's Avatar
Cool
Since nobody chimed in,I would wiggle the iac wires,and wires leading up the map sensor(mines a 93 on top of the manifold),and see if this helps.Take it for a drive,or sit and idle for a few minutes after you have moved the wires with your hand,(bend them).If you find that moving the wires has helped,then I would replace the wires.My02
Old Jun 21, 2003 | 04:28 AM
Est96Z28's Avatar
I had the same kind of problem and also cleaned IAC, which did help for a while, but then idling got progressively worse so I just went out and bought new IAC and my problems were solved.
Old Jun 21, 2003 | 05:36 PM
MLTA96's Avatar
where's the cheapest place to get it? i'm also having the same troubles.
Old Jun 21, 2003 | 06:32 PM
ScreamingChicken's Avatar
i bought mine from Discount Auto for like $120, cleaned up my original one, and returned it as if it were the new one.
so you may be able to get one for free.
Old Jun 21, 2003 | 06:51 PM
94camaro34's Avatar
not sure if its the same on the v6...but i had the same problem and bought a new one after many times of cleaning mine....29.99 at murrays....helped a lot....problem solved
HectorM52
Jul 30, 2017 11:46 AM
lt1matt
Mar 21, 2015 07:35 PM
silvermansteve
Mar 4, 2015 05:02 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
