My hawks been hybernating for 4 years with a full tank of gas! Is this a problem?
Old Nov 3, 2003 | 03:36 AM
Rob94hawk's Avatar
I have a full tank in the hawk which has been sitting up on jackstands for 4 years. My question is, if I need to drain the tank how do I drain 15 gallons?! Or can I dump some gas additive and just change the fuel filter?
Also, since the car has been sitting for this long should I change out the O rings in the fuel injectors? Or anything else for that matter?
Any advice for bringing my hawk out of hibernation is most appreciated! Thanx, Rob
Old Nov 3, 2003 | 05:04 AM
ChevyIron's Avatar
Rob my camaro was on jacks in my garage for about three years and the car started right up know problems.I would try to drive to almost empty then fill up with the good stuff.Rob Im on the island to what part of the island you at.Im in Glen Cove good luck with your car Bro
Old Nov 3, 2003 | 05:05 AM
predator's Avatar
well test the gas and see if it is laquered if not should be ok quite possible the injectors could be laquered
Old Nov 3, 2003 | 05:19 AM
magius231's Avatar
I wouldn't even take the chance...find some way to drain that gas out of there. you coulddisconnect the fuel line and jumper the fuel pump lead to the battery, pumping it all out...just be careful because if you run it totally dry this way it WILL burn up your fuel pump. I recommend getting a helper and disconnecting the line before the fuel filter so you don't clog it up.
Gas sitting for that long without any additive has more than likely broken down and needs to come out of there.
Old Nov 3, 2003 | 05:46 AM
bad96firechikin's Avatar
I'd be worried about the seals drying up too...mine sat up for 2 years, and when I finally pulled it out again, it was a oil leaking disaster. Rear main, all the front seals leaked, the rear main leak got so bad that it ruined my clutch after a short while...
Old Nov 3, 2003 | 09:06 AM
CamaroGuy22's Avatar
My question is, why would you let your car sit that long?
Old Nov 3, 2003 | 09:15 AM
Amped96's Avatar
My car sat for about 3 years previous to me buying it. The previous owner wrecked it, then sat it on jack stands until they finally decided to sell it and we bought it. The car cranked right up when we got there, but it didn't run so well. We drained the gas out (wasn't very much in it at all) and put some new gas in and she ran fine, except for a small miss it had from a bad plug wire.
Old Nov 3, 2003 | 10:00 AM
NewbieWar's Avatar
well according to my father: gas's lifespan is about 6 months, and i forget what happens to it after that
Old Nov 3, 2003 | 10:39 AM
RedPhenx's Avatar
if it was all the way full, it should be ok, so long as no air is in the tank. My fiero sat for almost 5 years while i was building engine etc, with a full tank. It started right up and still got about 250 miles out of the gas.
Old Nov 3, 2003 | 10:43 AM
BUBBA's Avatar
Use it up.
Old Nov 3, 2003 | 10:56 AM
GREGG 97Z's Avatar
I would drain it and put it in a beater. I thought I had some bad gas in mine recently when I was having prolems with the fuel pump. I drained about 10 gallons out and put it in the wifes Honda
Old Nov 3, 2003 | 11:14 AM
zhevy-1's Avatar
That's how you do it. Mine has been sitting around since April last year. It wasn't until March this year that it occurred to me, my gas may go bad. I put in some gas preservative, to prevent it from varnish, I still think it was too late. I'll be draining it all out per the method described above.
Old Nov 3, 2003 | 11:51 AM
BigJustinZ28's Avatar
hehe my 79 blazer eats crud for breakfast . 5 year old gas in it hehe , put 5 gals of clean premium in it and burned it through without a problem heheh. Drain the gas and use it for something else like a beater or something.
Old Nov 3, 2003 | 12:01 PM
96 WS6's Avatar
LOL, nice... I would say change the oil and filter, fuel filter, you could siphon the gas out if you wanted to... maybe it would be a good idea to get a gallon of denatured alcohol from the hardware store for 10 bucks to increase the octane a bit.
Old Nov 3, 2003 | 01:49 PM
BigRich's Avatar
SeaFoam is a water eliminator in gas and is recommended before storage, so it could help
