My goal is 12's help me get there!!
Re: My goal is 12's help me get there!!
no. checkout this thread, they wee talking about what it would take to get 12s
http://web.camaross.com/forums/showthread.php?t=460324
Originally Posted by slow95camaroz28
Im looking for 12's what do i need to get there?
Secondly, why didn't you search about this? This question has been asked just as much as "What is the first mod I should do to my LT1"
How do you want to get into to the 12s? Nitrous? Bolt-ons? Cam?
Please just do a search. This has been asked a million times.
Back in the day when I was running some boltons, I hit 12's in my 95 m6 with the following. It can be done, and at the time that I did it (1997), everyone thought my car was a freak. I had- mac midtube headers with off road pipes, underdrive, adj fuel regulator, cold air intake, msd, airfoil, and borla catback, and a JET pcm module. I was running mccreary dot's with skinnies in the front on weld prostars with the stock 3.42. I pulled a 1.94 60 foot and my et's were 12.90's at 107mph. So, it can be done if you drive the hell out of it, and put it on a sticky tire....I imagine if i would have had a 4.10, maybe some rockers, and ewp back then, I could have went mid to low 12's with a relatively full weight bolt on car. Hope this helps
As said before, what do you run? Some people need a cam to hit 12's, others do it with half of the bolt ons. It depends on your driving skills, some people can cut great 60fts and run 12.90's @ 105 and some run the same et with a 114 mph trap. Your going to need most of the bolt ons and a good 60ft (1.8x). good luck
Whats sad is I havent been to the track. I know my first time out I will not be there, but that is my goal for now just trying to figure out what I need to get there.
