My gas in the tank of the Z is "Boiling"? Scary!!
Old Apr 17, 2004 | 02:34 PM
Smokn '94 Z's Avatar
Unhappy My gas in the tank of the Z is "Boiling"? Scary!!
Well I just had gotten back home from a long hour cruise. Anyway when I got out of the car I heard what sounded like a major air leak in a tire but it sounded like it came from the muffler, so I let it sit about a half hour while I had lunch. It was a hissssssssssssing sound. Anyway I just went out to pull the car in the garage from the driveway and the car took a while to start for the first time that I can ever remember. I got the car into the garage and shut it off again, and again it was making the hisssssssssing sound. I crawled under the car and heard a gurgling/boiling sound along with the hissing sound. I quickly opened up the gas cap to see if it would relieve any pressure and it did, and instantly the hissssing went away but the boiling sound was still there. I am thinking for some reason the gas had gotten to hot but if so then why all of a sudden? This is the first time this has happend to me?
Eddie
Old Apr 17, 2004 | 02:49 PM
bunker's Avatar
Hmm... Sounds like your fuel pump is on its way out bro. The pump is getting real hot & boiling the fuel, hence why it also took a while to start.
The hissing sound your heard was your high pressure relief valve located by the tank so if the pressure exceeds normal it'll relieve the pressure, this is caused from the boiling you are describing, it'll also mainly happen when car is standing around/idling becuase your charcoal canister isn't being purged unless you are cruising at a certain speed/rpm.
Hope this helps.
Old Apr 18, 2004 | 12:10 AM
Hope this helps.
Well the pump is the original. The Pump will get that hot to cause the fuel to get that hot? I can't believe the pump just wouldn't completely fail before it got that hot. That is scary.
Old Apr 18, 2004 | 08:23 AM
I would be skeptical about it really boiling. Perhaps there was some air trapped somewhere that was making it bubble. Boiling? I just don't see how it could get that hot.
Old Apr 18, 2004 | 09:15 AM
Lightbulb
Well whatever that boiling sound was it wasn't what I would want to hear from the tank. So Shoebox, you agree that it is an issue with the pump going bad too? I will try to start it again in a little bit. I guess I can get a Fuel Pressure gauge and check it.
Eddie
Old Apr 18, 2004 | 09:49 AM
Cwynn's Avatar
Can gas boil? I thought it would burn before it did because it would have to be undergoing a phase change (liquid to gas) to actually be boiling.
Old Apr 18, 2004 | 10:10 AM
dnlFF's Avatar
let's just say your working on injectors on a hot engine. Gas comes out of the injector onto the intake it will boil like water does. Its is kinda scary lol. But no harm.
Old Apr 18, 2004 | 10:53 AM
Eddie
Hard to say. It could be just a pressure build up. Maybe the vent was/is stuck or something? Or there is a valve by the EVAP canister that might be acting up.
I had a weird happening on my Grand Prix a few years ago. It was getting excess pressure in the tank and when I would take the cap off, air would just practically blow out the filler (and I was a thousand miles from home on vacation ). It did not seem to bother drivability, but my first indication of something wrong was that the fuel pump was sounding louder. Eventually it cleared up on it's own. That was almost 4 years ago and it has not been a problem since.
Old Apr 18, 2004 | 12:00 PM
Lightbulb
Well I had it on my list to put in a new pump anyway. Maybe now I won't procrastinate anymore. I just hate to have the car break down on the road especially if my pregnant wife is with me. She hates the car and the $$$ I put towards it already, can you imagine if yesterday I didn't make it home with her and her very pregnant mood swings with me?
Thanks guys....
Nayr
Mar 3, 2023 08:34 PM
Pwilson59
Sep 3, 2015 08:47 PM
350350
14
Aug 11, 2015 12:03 PM
Alibi
Aug 1, 2015 07:50 PM
Anon
Jul 23, 2015 12:18 PM
