my frame is bent
Old Apr 4, 2005 | 02:01 PM
TransAmTONY's Avatar
my frame is bent
i was at pep boys getting my car aligned after i dropped it 1inch and the mech there couldn't get the caster/camber right and it turned out that one of the adjustment bolts that is attached to the frame is bent. I havn't had time to study it in depth or look at it closely.
My question is : How hard is to replace the front left subframe?
I would assume i would have to support the engine, remove lines running along it, detach suspension components...
On a side note i cannot junk this car. It has too much money/sentimental value to toss aside becasue of a lousy bent frame.
Thanks for ya'lls time.
-Tony
Old Apr 4, 2005 | 03:51 PM
RE AND CHERYL's Avatar
Re: my frame is bent
Is it the frame or the bolt?
If the bolt is bent, replace it and see if it's straight enough to align. If your K frame is bent there would surely be a hell of an impact mark somewhere on it.
Old Apr 4, 2005 | 11:36 PM
Z-RATED94's Avatar
Did the mech explain to you what parts needed to be replaced? Sounds like you need a second opinion. Ditch Pep boys and find a real alignment shop.
HibachiZ28
Nov 6, 2015 12:53 AM
football4life
Oct 4, 2015 07:48 AM
CARiD
Sep 30, 2015 05:44 AM
Daluchman1974
Sep 11, 2015 06:12 AM
detroitmuscle
Jul 31, 2015 04:21 AM
