My first engine build
Old Jun 2, 2016 | 01:36 AM
thenewkid's Avatar
Hey everyone, I need some advice again. I'm getting ready to start my first lt1 build. I made the decision last weekend, while I was at the junkyard I was able to pull the heads, intake, and water pump from a 95 Fleetwood. The goal is to make a street engine with good performance using iron heads. I'm thinking about a 355 with a nice port job/ cam. I know iron heads don't take high compression as well as aluminum but I still feel like they can make power. It would also be cool to build something different. Let me know what you think, thanks
Old Jun 2, 2016 | 10:16 AM
Chimera96's Avatar
Re: My first engine build
Nothing wrong with the iron heads. They can be ported if you want. If going with a cam, you should consider having the press in studs pulled and machined for ARP screw in RR studs
I found this book very helpful regarding rebuild.
How to Rebuild Small-Block Chevy Lt1/Lt4 Engines Hp1393: Mike Mavrigian: 0075478003938: Amazon.com: Books How to Rebuild Small-Block Chevy Lt1/Lt4 Engines Hp1393: Mike Mavrigian: 0075478003938: Amazon.com: Books
Old Jun 2, 2016 | 11:02 AM
What are you putting the engine into? The B-Body water pump is not the same as the F-Body.
Old Jun 2, 2016 | 01:49 PM
thenewkid's Avatar
Oh dang. didn't notice that... It will hopefully go in my 94 camaro
Old Jun 2, 2016 | 02:01 PM
thenewkid's Avatar
I forgot to mention I just had the transmission rebuilt by CPT and went with a 2800 stall from protorque... 3.42 Gears at the moment. What would you suggest for a cam?
Old Jun 2, 2016 | 02:36 PM
Bolts to the block but the external connections are not the same.
Courtesy of Shoebox
http://shbox.com/1/lt1_water_pumps.jpg
Old Jun 3, 2016 | 01:32 AM
thenewkid's Avatar
Why are the corvette and b body so similar? is there a 'bypass' sort of like the throttle body coolant passage?
Z28Freak86
Apr 30, 2024 05:37 PM
kylekratzenberg
Jun 29, 2015 05:56 AM
blkcamaro_z28
Jun 25, 2015 12:07 AM
Geoff Chadwick
Jul 31, 2002 12:07 PM
