Is my exhaust slowing me down?
Old Apr 15, 2006 | 01:51 AM
jsetzer's Avatar
Went back out to the track tonight. I was just playing around on street tires so I don't car too much about my e/t. But my mph seems low for the motor to me.
357 eagle forged, flat srp pistons
12:1 compression
gm847
stock heads, 2.00/1.56 valves, 3 angle job, mild porting. Peak numbers were mid 250 flow on the intake
getto cold air, home made stock TB, ported intake
hooker long tubes, h pipe 2.5" duals, 40 series flowmaster x 2
6 speed + 10 bolt
best of the night was @ 12.809 @ 111.69 w/ 2.1 60ft.
I realize once I get my rear end / tires / supspension that thats enough to carry me to low 12s, however I really think something is missing. Also I probably need some more tuning as this is my pcm4less mail order tune for my cc306
Old Apr 15, 2006 | 02:10 AM
Z95m6's Avatar
Re: Is my exhaust slowing me down?
Your exhaust setup looks fine.
Old Apr 15, 2006 | 02:13 AM
jsetzer's Avatar
I just feel that even for mild heads my traps are low. Would a better 60' and better shifting (spinning on 2 and 3 shift, scratching 4th) impove my mph?
I was hoping for @ 115mph.
Old Apr 15, 2006 | 02:20 AM
Z95m6's Avatar
How high are you reving it? with that cam its gonna want to rev to make power.
Old Apr 15, 2006 | 02:33 AM
jsetzer's Avatar
Shifting 6600-6700. Limiter is at 6800 and I did hit it on a pass or two.
Motor would take higher if I need to spin it higher, guess its dyno time.
I have always heard bad things about flow masters, but usually its people talking about the 80 series. If my 2 40s aren't hurting me I will just let them be, allthought I was looking at some sweet thunder 24" ones.
Old Apr 15, 2006 | 02:55 AM
Evil Eric's Avatar
dude I'd think from what ive seen posted on here that an 847 and mild heads would be good for high 11's
Old Apr 15, 2006 | 03:01 AM
Digital Designs's Avatar
getting close to a 1.6-7 60' foot would put you in the 11.9-12.1 range
Old Apr 15, 2006 | 05:37 AM
MeanGreen97Z's Avatar
I think that exhaust is more than addequate. I believe there is a little in the tune. Not too much but some. Is the tune set up for 12:1 compression?
Old Apr 15, 2006 | 08:35 AM
89385formula's Avatar
I highly doubt your exhaust is slowing you down. Flowmasters flow rather poorly, moreso on the crossflow type mufflers....however with 2.5" true duals they flow more then enough for your setup. You may gain a small amount by swapping them out, but probably not enough to make it worthwhile.
Old Apr 16, 2006 | 10:17 AM
my94blackz's Avatar
Your times seem really low for your set-up. I have stock ported heads, stock valves, full bolt ons, 233/239 cam, full weight, true duals 2.5, slp headers, and a forged 355 with about 11:1. I netted a 12.1 @116 with a 1.9 short time. I was spinning off the line. If i woulda hooked that pass it woulda been a 11 sec pass easy.
Old Apr 16, 2006 | 10:30 AM
Chopstix's Avatar
I made 1 street tire pass in the 94....it went 12.94 @113 on a 2.5 60' (26" tires and 4.10 gears)
on slicks it went 11.6 @ 119 (28" tires and 3.73's)....it would trap over 120 on the 26's
with sticky tire and a better launch I think you will find your missing MPH
2 things that will also affect trap speeds are density altitude and raceweight
Old Apr 20, 2006 | 11:22 AM
jsetzer's Avatar
Shes fat, 3710 with me. And just re adjusted the valves, a couple were overly tight. Seems to run a bit better now. Dyno scheduled in 2 weeks. Will report back.
Old Apr 20, 2006 | 02:40 PM
RedRyder518's Avatar
Hey jsetzer, you don't happen to live in OK, do you?
Old May 1, 2006 | 11:37 AM
jsetzer's Avatar
Sure do, and I happen to know of a little red SS that came to visit me years ago.
Going to the dyno on Wed... if I can't find my missing power Ill just spray the damn thing.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
May 21, 2015 01:04 PM
beltrunner
May 17, 2015 10:18 PM
May 15, 2015 10:43 AM
blkWidow
Apr 21, 2015 01:56 PM
