My coolant is milky white?
Old Aug 22, 2007 | 01:00 PM
  #16
rickreeves1's Avatar
Originally Posted by shoebox
That's a myth. The coolant manufacturers even say they can be mixed. The only thing you lose by diluting Dexcool is the extended maintenance interval and compromise of the silicate free solution.
I disagree. I have seen what Dexcool mixed with Green Coolant in a coolant system looks like. It turns into an orange sludge. This occurs more rapidly if air is also introduced into the system. It almost cost me a couple thousand in repairs and replacement parts for the coolant system. It was also most likely the cause of a blown head gasket I had. Ask someone who services coolant systems for a living what they think of Dexcool. There is a new type of coolant that is clear in color. This type is said to be safe to mix.
Old Aug 22, 2007 | 04:00 PM
  #17
It's the air introduction, not the mixing. A tight system is not going to have any problem.
Old Aug 22, 2007 | 04:17 PM
  #18
Sparkz28ss's Avatar
werd.......the difference is the bisulfates
Old Aug 22, 2007 | 04:34 PM
  #19
SS RRR's Avatar
Reads like it's still not a good idea to mix the two...
Old Aug 22, 2007 | 05:17 PM
  #20
Not my statement.
Still, I don't mix coolants. Unless one or the other is not available and it is an emergency, most people never will.
Old Aug 22, 2007 | 11:10 PM
  #21
camaroguy1984's Avatar
ok drained the oil
ok so yesterday i drained the oil and it looks fine doesnt look to have water or coolant in it whats another way to tell if i have a blown head gasket other than compression test?
Old Aug 22, 2007 | 11:22 PM
  #22
If you were burning coolant, a plug (or plugs) would be clean looking, you would see white vapor from the exhaust and your coolant level would be going down. You can also buy a kit to test for the presence of exhaust vapors in the coolant. If you have none of these symptoms and did not have the milky substance until you introduced it with the flush, I would say you are chasing your tail.
Old Aug 23, 2007 | 03:44 AM
  #23
Bump Stick's Avatar
short of pulling the head and inspecting a compression or leak down test is the only way to know (bad rings would show on those). That what you are goign to need to do.
Old Aug 23, 2007 | 04:25 AM
  #24
henryz28's Avatar
I think its the excess milky flush stuff you used. Because I just used some milky looking anti rust this weakend and now my coolent looks milky.
Old Aug 23, 2007 | 10:48 AM
  #25
One other way would be to have an oil analysis done. They can check for traces of coolant in the oil. It may be too late for that if you have drained the oil.
http://www.blackstone-labs.com/
Old Aug 23, 2007 | 12:32 PM
  #26
was it made by prestone?
Old Aug 23, 2007 | 09:08 PM
  #27
Interceptor1's Avatar
Does your car have an automatic transmission?
I had a long time ago an Olds Cutlass with a 350/TH350. One day checking the coolant level I noticed milky residues in it and I thought it was an oil leak, but the oil level was ok, so I just drained and replaced the coolant. I checked it a couple days later and it was the same or worse, it looked like vanilla milk shake. When the car was cold or cool everything was ok, when it reached operating temp the transmission started to slip a lot.
It turned out that the leak was from the automatic transmission cooler line inside the radiator, somehow it had fractured or rusted open so the radiator had ATF in it and my tranny was working with coolant and water inside. It was 4 days from when I changed the coolant, to when the tranny died (the car wouldn't even go up the driveway) and I had to replace it, and the radiator too.
Old Aug 28, 2007 | 01:41 AM
  #28
henryz28's Avatar
I am kinda of late but yes it was prestone.
Pwilson59
Sep 3, 2015 08:47 PM
30th Anniv Z28
Aug 1, 2015 10:39 AM
Thirim
Jul 30, 2015 01:29 PM
Noct
Jul 14, 2015 01:18 AM
Fastbird93
Jul 11, 2015 04:37 PM
