Are my Comp R's bad?
Old Jul 17, 2005 | 03:55 PM
wicked_95z's Avatar
Short history. I trashed the bearings in my motor though they never spun. Pulled the intake off and it looked like someone sprinkled glitter in the lifter valley. New motor coming Monday. In the process of cleaning up the lifters, I was blowing into the top of the lifter and on some of the lifters the air would push out any oil left in them from the hole on the side. On about 5 of them I couldnt blow any or very little air out. To me this would suggest my oil passages are blocked. Is there any way to take them apart and clean the passages or do I just bite the bullet. I tried pipe cleaners with no improvement. thanks
Old Jul 17, 2005 | 11:17 PM
Dan Parker '96's Avatar
Re: Are my Comp R's bad?
I would not use any component other than a very well cleaned block if you've had a bearing failure.
The fine particles manage to ruin every other close tolerance piece in the engine.
Replace everything.
Old Jul 17, 2005 | 11:19 PM
turbo_Z's Avatar
Comp R lifters are JUNK! Id go with a new set of 850s from Comp.
Old Jul 18, 2005 | 05:27 AM
wicked_95z's Avatar
Where did that come from? What bad experience did you have with them? What are the 850's, I thought Comp R's were pretty high on the list of lifters available. They've been good to me so far.
Old Jul 18, 2005 | 05:37 AM
wicked_95z's Avatar
Nevermind, I just read and 8 page post about the Comp R's. Do you think the 850 OEM replacements will be okay for a 224/236 XE cam on bee hive springs?
Old Jul 19, 2005 | 11:07 AM
turbo_Z's Avatar
Absolutely. I run stockers with my 224/230 XE and have not experienced any problems spinning the motor to 6k rpm but the springs I am using are the CC987s which I believe are every bit as strong as the 918s if you read the specs... some people disagree about that though. The 918s are supposed to be easy on the lifters anyway and some of the guys like SStrokerAce recommends the OEM replacement lifters... they are MUCH quieter than the R series as well.
Old Jul 19, 2005 | 02:41 PM
ktg's Avatar
ktg
Another vote for 'Comp-R's suck!'.
Old Jul 19, 2005 | 05:49 PM
wicked_95z's Avatar
The duration is smaller than my last hyd cam but the lift is more
new Cam 224/236 116LSA XE .606/.628 w 1.6
my old cam was a 24x/25x with just under.600 on intake and just over .615 on exhaust
oldschool
Feb 9, 2016 09:21 PM
MadMav
May 25, 2015 09:35 PM
mightymouse383
May 21, 2015 05:31 PM
BLK1997Z28
May 7, 2015 03:01 PM
