my car is still having problems
the car dies on me when I take off from a stop,and then wont start for awhile, it idles fine,fuel pressure is fine,volts are fine, runs great when it runs,but dies on me
so far ive replaced the fuel filter,the intake elbow because it was crushed causing me to have a vacuum leak,and the coil
im guessing the only thing left is the opti? the car isnt throwing any codes,doesnt seem down on power,and the opti has been changed in the last 25k miles
Re: my car is still having problems
Don't see why the distributor would be the cause of a problem that occurs only when you try to leave a light???? Sounds either fuel related or sensor related.
Have you scanned it for codes?
Have you checked the fuel pressure when the problem occurs or only when it was idling?
Originally Posted by 1FstFormulaV8
When you do try to restart. Does it just crank and not fire? How long do you usually have to wait until the vehicle starts?
I'd check for leaky injectors. I'd replace the spark plugs and wires if you haven't replaced them in a long time and if they are due for replacement anyway. If wires are new, test them with an ohm-meter(multi-meter). Is your MAP connector fine, meaning no broken tabs? Hows the oil, normal level and regular colored?
i dont remember for sure, but I think the oil is supposed to be changed, right after seafoam is used.
What caused your intake elbow to be crushed,is the new one seated allthe way on the trottle body,check under the elbow at the trottle body.
The egr valve is it stuck open? what about the o2 sensors are they
working properly after using the sea foam?
