So who has changed the Valve Springs with heads on the car?
Old May 11, 2006 | 03:32 PM
Bow94z's Avatar
What was the expericne like?? or is it worth pulling the heads to compress the spring onto it.
I wanted to freshen up the top end on my car with some LT4 springs/locks/retainers, and some 1.6 rockers on 140K mile motor..
What do u guys Think?
Old May 11, 2006 | 03:33 PM
jsetzer's Avatar
Re: So who has changed the Valve Springs with heads on the car?
Not fun, but doable.
I think shbox.com has a good guide.
I have done it 2x. First was easy (stock springs) after that it was a nightmare. I would not do them on the car again...
Old May 11, 2006 | 03:36 PM
1SlowFormula's Avatar
Wondering the same thing, I will be doing the same thing soon too. I have the 1.6RR's already and have the springs and other accesories coming in hopefully this week to start on it this weekend...
I'm not too far if your interested in coming down and helping...
Old May 11, 2006 | 04:12 PM
nb 96 z's Avatar
Its not too bad. Mechanix gloves will help a little since your hands will get raw after turning the tool a while. I thought it was easier than to take off the heads.
Old May 11, 2006 | 04:30 PM
Jazsun's Avatar
I say it time and time again, if you get the comp cams tool which bolts to the rocker studs its easy as hell and takes 1/3 of the time. I did it prolly 4 times both 2 each way.
Old May 11, 2006 | 04:35 PM
94superZ's Avatar
I've done it a couple times using the screw-type compressor. No problem - for the heavy springs I wrapped a strong zip tie around so the tool wouldn't slip off. It happened once and the retainer flew off and hit me in the safety glasses. I'd probably be blind if I wasn't wearing them.
I also have the comp angle bar that bolts on and when there's clearance that works good too.
Old May 11, 2006 | 04:46 PM
wrd1972's Avatar
The hardest part is doing the rear pair on each side. The rest are cake as long as you pay attention and take your time. I did the whole thing in maybe 2-3 hours.
Old May 11, 2006 | 06:33 PM
stroked383z28's Avatar
I use the crane tool that does two springs at a time and it's a piece of cake. Well worth the money.
Old May 11, 2006 | 07:09 PM
Loadre's Avatar
I've heard that tool is great. You can also use the custom tool offered in the 'Tools' section of LS1tech (Tim's valve spring tool). I prefer using these to take them off and a screw type to stick 'em back on.
Old May 11, 2006 | 07:38 PM
Did you really remove the studs and replace them with that one he supplies for every spring? That seams like more work, or can you use your own stud but just not for longer/taller springs? At least for getting them back on?
Old May 12, 2006 | 01:27 AM
camarolover20's Avatar
I would love to give u a hand.I'm also thinkin about doing the same thing to my car since I already have the lt4 spring.
Old May 12, 2006 | 02:05 AM
Z95m6's Avatar
You mean the Crane Cams tool?
Old May 12, 2006 | 07:16 AM
I still haven't gotten my parts and if they don't come in later today then I will not be doing anything until at least next weekend. But if your interested in stopping up PM me...
Old May 12, 2006 | 10:37 AM
Loadre's Avatar
That's just for the LS1 tool. For the LT1 tool you bolt it down to your existing 3/8 or 7/16 rocker studs. Yes on taller springs putting them back on is a PITA that's why I like using a screw type to stick them back on (I think he is going to start providing a longer stud to fix this problem though). The screw type with the nut on top to use a 3/8 ratchet is even better.
Old May 17, 2006 | 04:16 PM
z275plus's Avatar
You can get the crane tool from thunder racing,works like a champ.Did mine a few weeks ago . Had to take a round file to open up one of the holes on the spring tool a little was just a little tight on some of the studs and would not go all the way down,after that it worked great,only took a minute to do.Well worth the money.
You can use your stock rocker studs without a problem. Just be sure to bring the pistons up to TDC so the valve will not fall into your engine.
Change your valve seals also very easy to do while you are changing the springs.They can just be pulled off with a pair of pliers. You'll be glad you did.
