my car is running like crap
Old Apr 9, 2007 | 09:31 PM
Spencez28's Avatar
Ok, i have a 94 z28 with 121k miles on it. (Videos at the bottom of post)
I have some serious rpm fluctuating
Im fairly sure my problem has something to do with the ignition system. Ive had some studdering for a year or so now but lately its been getting bad. it doesnt seem to bad when the engine is cold but once its up to operating temp its really noticeable.
Also im not sure if its related but it seems to get up around 210 degrees pretty quick if its not moving.
drivinghttp://s55.photobucket.com/albums/g1...t=P4090031.flv
ya i had to mount the cam on the wheel so it move a little...
idle and revhttp://s55.photobucket.com/albums/g1...t=P4090033.flv
When its sitting at 800 and bumps up to 1000-1100 thats not me, it does that on its own, Also the speedo moves up past 10mph in this video but the car isnt moving...not sure what thats about
Old Apr 9, 2007 | 11:52 PM
wheelliftnpony's Avatar
might be off topic, but look at that oil pressure... make sure theres enough in there..... that could definately effect how fast it heats up as well.. and as far as ignition goes, u could take it to advance autoparts and have them scan it for any kind of problems there..auto zone only does OBD II cars i believe but advance does them all... if u replace the ignition, my 94 just got the MSD unit and it helped a LOT. dist, coil, cap n rotor button.. hard to do and pricey, but worth it
Old Apr 9, 2007 | 11:56 PM
scott9050's Avatar
Original opti? Check the obvious first, arcing wires, bad plugs, carbon tracked cap and rotor. Also check for a sticking IAC valve and vacuum leaks.
Old Apr 10, 2007 | 12:48 AM
EviLZ28's Avatar
I would say the Opti is on its way out.
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
nophix
Nov 30, 2014 10:26 PM
USAirman93
Nov 24, 2014 03:37 PM
